Dear Sir,
Im trying to upload linux system on apalis T30 using Apalis_T30_LinuxImageV2.6 with my custom rootfs. I have already changed EMMC_SIZE to: **EMMC_SIZE=$(expr 1024 \* 7450 \* 2 \* 2)** The problem which I
m facing is that system is not probably loading completely. After runnig update.sh script I can see as follows:
Creating MBR file and do the partitioning
0+0 records in
0+0 records out
0 bytes copied, 0,000119793 s, 0,0 kB/s
Model: (file)
Disk /home/kamil/apalis/debian_wheezy/apalis-t30_bin/mbr.bin: 30515200s
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 8192s 40959s 32768s primary lba
2 40960s 30474239s 30433280s primary
Creating VFAT partition image with the kernel
mkfs.fat 3.0.28 (2015-05-16)
mkfs.fat: warning - lowercase labels might not work properly with DOS or Windows
Creating rootfs partition image
2758+0 records in
2758+0 records out
2891972608 bytes (2,9 GB, 2,7 GiB) copied, 4,21305 s, 686 MB/s
mke2fs 1.42.13 (17-May-2015)
Discarding device blocks: done
Creating filesystem with 706048 4k blocks and 176704 inodes
Filesystem UUID: e3d8ad85-3e5b-4bcb-921c-1a37bce30068
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912
but after system is loaded The final partition is to small:
rootfs 2,5G 2,4G 0 100% /
/dev/root 2,5G 2,4G 0 100% /
devtmpfs 997M 0 997M 0% /dev
tmpfs 200M 212K 200M 1% /run
tmpfs 5,0M 0 5,0M 0% /run/lock
tmpfs 399M 0 399M 0% /run/shm
tmpfs 399M 4,0K 399M 1% /tmp
How can I increase the rootfs partition on Apalis T30 before system copy?
