"Bad device mmc 1" using "run setupdate"
Preparing to Flash to my Apalis i.MX6 via SD card I get the following error when I run setupdate:
Apalis iMX6 # run setupdate
MMC: no card present
** Bad device mmc 1 **
reading flash_blk.img
710 bytes read in 21 ms (32.2 KiB/s)
Executing script at 12000000
reading apalis_imx6/flash_blk.img
3978 bytes read in 18 ms (215.8 KiB/s)
enter “run update” or “run update_it” to update the entire module
Apalis iMX6 # run update
Since the script runs, am I OK?
Hi
.> Since the script runs, am I OK?
Yes.
Background:
The Apalis has two interfaces to MMC/SD cards, the first one called MMC (up to 8bit data bus), the second called SD (up to 4bit data bus).
On the Ixora V1.1 the SD interface is used for the micro SD slot.
The script checks first the availability of a card on the MMC interface and when this fails outputs the Bad device mmc 1 message and continuous by trying the SD interface.
Max
Great, Thanks for the clarification.
