Looking at your custom Plymouth setup, I can identify several issues that are preventing your splash screen from displaying. Let me walk you through the corrections needed based on the Toradex documentation.
Issues with Your Current Setup
1. File Installation Path Errors
Your .bbappend file has incorrect file paths for the PNG images:
install -m 0644 ${WORKDIR}/frame01.png ${D}${datadir}/plymouth/themes/custom/frame01
install -m 0644 ${WORKDIR}/frame02.png ${D}${datadir}/plymouth/themes/custom/frame02
These should include the .png extension in the destination paths.
2. Script File Error
Your custom.script file has a typo - spr.SetZ(15); should be sprite.SetZ(15);.
3. Configuration File Location
The plymouthd.defaults file should be installed to /etc/plymouth/ rather than /usr/share/plymouth/.
Corrected Implementation
Based on the official Toradex documentation (1), here’s how you should structure your files:
Updated plymouth_%.bbappend
FILESEXTRAPATHS:prepend := "${THISDIR}/files:"
SRC_URI += " \
file://custom.plymouth \
file://custom.script \
file://frame01.png \
file://frame02.png \
EXTRA_OECONF += "--with-runtimedir=/run"
do_install:append () {
install -d ${D}${datadir}/plymouth/themes/custom
install -m 0644 ${WORKDIR}/custom.plymouth ${D}${datadir}/plymouth/themes/custom/custom.plymouth
install -m 0644 ${WORKDIR}/custom.script ${D}${datadir}/plymouth/themes/custom/custom.script
install -m 0644 ${WORKDIR}/frame01.png ${D}${datadir}/plymouth/themes/custom/frame01.png
install -m 0644 ${WORKDIR}/frame02.png ${D}${datadir}/plymouth/themes/custom/frame02.png
Corrected custom.script
image = Image("frame01.png");
pos_x = Window.GetWidth()/2 - image.GetWidth()/2;
pos_y = Window.GetHeight()/2 - image.GetHeight()/2;
sprite = Sprite(image);
sprite.SetX(pos_x);
sprite.SetY(pos_y);
fun refresh_callback () {
sprite.SetOpacity(1);
sprite.SetZ(15);
Plymouth.SetRefreshFunction (refresh_callback);
Theme Selection Method
Instead of using plymouthd.defaults, you should set the theme using a post-process command in your image recipe or local.conf. Add this to your local.conf:
ROOTFS_POSTPROCESS_COMMAND += "set_plymouth_theme;"
set_plymouth_theme() {
plymouth-set-default-theme custom --rebuild-initrd
Alternative Approach Using Toradex Example
The official Toradex documentation (1) shows a simpler approach using the existing spinner theme structure:
SRC_URI += " \
file://spinner.plymouth \
install -m 0644 ${WORKDIR}/frame01.png ${D}${datadir}/plymouth/themes/spinner/watermark.png
install -m 0644 ${WORKDIR}/spinner.plymouth ${D}${datadir}/plymouth/themes/spinner/spinner.plymouth
This approach modifies the existing spinner theme rather than creating a completely new theme, which can be more reliable.
Build Process
Make sure you’re building with the correct image recipe (3):
$ bitbake tdx-reference-multimedia-image
Verification Steps
After deployment, verify:
- Your theme files are present in
/usr/share/plymouth/themes/custom/ - Check the active theme:
plymouth-set-default-theme --list - Ensure Plymouth is enabled in the boot process
The black screen issue is likely due to the file path errors and the script typo preventing Plymouth from loading your custom theme properly.
