Hallo,
As I could read, the AX88772B as extra NIC is supported by the image.
Will the C version (AX88772C) also work?
Thomas
Hallo,
Thomas
Dear @TJO
We never tried to use the AX88772C. The driver source code we use for the AX88772B also mentions the AX88772C in some places, so it is possible that it works right away.
If you plan to use the 772C I recommend to purchase an evaluation board that you could connect to one of the regular USB ports of the Colibri carrier board.
Regards, Andy
