I couldn’t find information of how the AutoCopy function handle read only files?
Will it ignore copy if it has to overwrite a read only file?
Does it change the file properties for copied file?
Thomas
Thomas
File properties are not changed. If you have a file in \Autocopy with a read only property it gets copied the first time. If a readonly file is already there at the target, the file gets not overwritten.
