Hi, I’m having apalis IMX8 module and need to run ELF file autonomously after the module boots. What is the procedure for that? Explain steps by taking an example.
I am following this link:
Hi @kamal12,
Can you share more detail if you are facing issue in any given steps in article and where this elf file is suppose to run under? Is this UI application or headless?
Additionally please do share if you are using Torizon or Linux BSP and their version.
Ritesh Kumar
