Aquila AM69 ETH_2 SerDes Mode Support: QSGMII / MP-USXGMII Clarification
I am designing a custom carrier board for the Aquila AM69 Octa 32GB IT, and I am evaluating options to maximize Ethernet port count while retaining TSN capability.
From the Toradex Pinout Designer, ETH_2 appears to expose multiple SerDes mode options, including:
ETH_2_QSGMII
ETH_2_SGMII
ETH_2_USXGMII/XFI
ETH_2_XGMII
ETH_2_SGMII/XAUI
I would like to clarify what is supported by the Toradex BSP and device-tree configuration.
Specifically, does the Toradex BSP for Aquila AM69 support ETH_2 in either of the following multi-port modes?
  1. QSGMII mode
    One SerDes lane carrying four CPSW MAC ports to a quad 1GbE PHY, for example Microchip LAN8804.
  2. MP-USXGMII / 10G-QXGMII / similar multi-port USXGMII mode
    One high-speed SerDes link carrying four logical Ethernet ports to a multi-port PHY, for example Marvell 88X3540 / Alaska X family.
Or is ETH_2_USXGMII/XFI supported only as a single-port SGMII / USXGMII / XFI interface?
My target Ethernet configuration is currently:
ETH_1: On-module 1GbE PHY, TSN-capable
Module-specific SGMII ports:
    4x external SGMII PHYs, ideally 2.5GbE with TSN support
ETH_2:
    Option A: QSGMII to quad 1GbE PHY
    Option B: MP-USXGMII / multi-port USXGMII to quad multi-gig PHY
    Option C: single-port SGMII / USXGMII / XFI if multi-port modes are not supported
I also want to confirm whether using ETH_2_QSGMII would consume or conflict with the separate module-specific SGMII[5..8] ports. In other words, can the four discrete SGMII ports and ETH_2_QSGMII be used simultaneously, or do they map to the same internal CPSW ports / SerDes resources?
Could you please clarify:
  1. Which ETH_2 modes are validated in the Toradex BSP?
  2. Which CPSW MAC ports are mapped when ETH_2_QSGMII is used?
  3. Whether MP-USXGMII / 10G-QXGMII / multi-port USXGMII is supported in the BSP, device tree, and SerDes configuration.
  4. Whether there are validated PHY examples or reference device trees for:
    • QSGMII quad PHYs such as Microchip LAN8804
    • multi-port USXGMII PHYs such as Marvell 88X3540
    • single-port USXGMII/XFI PHYs
  5. Whether TSN features are supported on all external CPSW ports in these configurations.
Dylan,
For Aquila AM69, it is important to distinguish between the two Ethernet subsystems on the SoC:
The MCU CPSW0 subsystem is a two-port Gigabit Ethernet MAC. According to the AM69 TRM, Port 0 is the internal CPPI DMA host port, and Port 1 is the external Ethernet port. This external port supports RGMII/RMII and MDIO for PHY management. It is used for a standard 10/100/1000 Ethernet interface and is not related to the SerDes-based SGMII/QSGMII/USXGMII/XFI options.
The additional SerDes-based Ethernet interfaces are handled by the main CPSW Ethernet subsystem. Therefore, for ETH_2, SGMII, QSGMII, USXGMII, XFI, or SFP+ use cases, the relevant items are the main CPSW port mapping, SerDes lane configuration, PHY mode, MDIO/SFP configuration, and BSP driver support.
Regarding the modes shown in Pinout Designer: these represent possible SoC/SerDes pinmux options, but they should not be interpreted as validated Toradex BSP configurations for every possible Ethernet topology.
For your specific questions:
ETH_2_QSGMII
QSGMII may be possible from a SoC/SerDes capability point of view, but we do not currently provide a validated Toradex reference device tree for ETH_2 connected to a quad QSGMII PHY such as the Microchip LAN8804.
If QSGMII is used, one SerDes lane carries multiple logical Ethernet ports. The exact CPSW MAC port mapping must match the selected SerDes lane configuration. Those CPSW ports cannot also be used independently through another SGMII configuration. Therefore, whether ETH_2_QSGMII conflicts with other SGMII interfaces depends on which internal CPSW ports are assigned to that QSGMII instance.
We do not currently have a validated Toradex BSP reference configuration for MP-USXGMII, 10G-QXGMII, or similar multi-port USXGMII modes connected to a multi-port PHY such as the Marvell 88X3540. Such a configuration would require support in the SerDes configuration, CPSW/phylink configuration, PHY driver, and device tree. Unless TI provides a directly applicable AM69/J784S4 Linux reference configuration, this should be treated as a custom integration effort.
ETH_2_USXGMII/XFI
At this point, I would treat ETH_2_USXGMII/XFI as a single-port high-speed SerDes Ethernet option unless a validated multi-port configuration is available.
Validated PHY examples
At this time, we do not have validated Toradex reference device trees for the following custom configurations on Aquila AM69:
  • Multi-port USXGMII PHYs such as Marvell 88X3540
  • Custom direct SFP+ 10GBASE-R/SFI configurations beyond the interfaces supported in the reference BSP
These may still be possible, but they would need to be validated as part of the custom carrier-board integration.
TSN
TSN support is provided by the AM69 CPSW hardware/software stack, but whether it is usable on every external Ethernet port depends on the selected CPSW port, PHY mode, external PHY capabilities, timestamping support, and BSP driver support. We cannot claim TSN validation for all possible QSGMII or multi-port USXGMII PHY configurations without validating that specific design.
For the next step, please share the exact target topology you would like to implement, including:
  • Which Aquila pins and SerDes lanes are intended for each Ethernet interface
  • Which CPSW MAC ports are expected to be used
  • External PHY part numbers
  • PHY interface mode for each port: SGMII, QSGMII, USXGMII, XFI, 10GBASE-R/SFI, etc.
  • MDIO bus and PHY addresses
With that information, we can review whether the selected SerDes lane mapping, CPSW port mapping, and PHY configuration are internally consistent and identify which parts are supported by the current BSP versus which parts would require custom validation.
Alexander Samutin
Toradex
Senior Field Application Engineer
Dylan,
ETH_2_QSGMII
ETH_2_USXGMII/XFI
TSN
Hello Alex,
Thank you for the detailed clarification.
We have not finalized the Aquila pinout yet. We are still early enough in the carrier-board design that we can choose whichever exposed Aquila pins / SerDes lanes are most appropriate. Our goal is to maximize the number of 1GbE ports while keeping the design practical and supportable on the Toradex BSP.
Our software baseline is:
Toradex BSP version 7
Custom Yocto image based on the Toradex reference image
AM69 meta-toradex-ti BSP
Aquila AM69/TDA4 ML/NPU support added using the Toradex Developer Center guide
We are no longer pursuing MP-USXGMII / 10G-QXGMII / Marvell 88X3540-style multi-port USXGMII for this carrier revision.
We would like Toradex to review two possible 1GbE topologies and advise which one is realistic with BSP 7.
Option A) preferred high-port-count topology: ETH_1 + dual QSGMII
This is our preferred topology if it is practical from the Aquila pinout, SerDes, CPSW9G, and BSP perspective.
ETH_1:
  Subsystem: MCU CPSW0 / on-module Gigabit PHY
  Target: 1x 10/100/1000BASE-T RJ45
  PHY: on-module PHY
  Interface mode: existing ETH_1 interface
Main CPSW9G ports 1-4:
  Interface mode: QSGMII
  External PHY: Microchip LAN8804 or equivalent quad 1GbE QSGMII PHY
  Target: 4x 10/100/1000BASE-T RJ45
  QSGMII carrier Aquila pins / SerDes lane: TBD by Toradex recommendation
Main CPSW9G ports 5-8:
  External PHY: second Microchip LAN8804 or equivalent quad 1GbE QSGMII PHY
Total target:
1x ETH_1 on-module GbE
4x GbE through LAN8804 #1
4x GbE through LAN8804 #2
Total: 9x 1GbE ports
We understand that each QSGMII instance consumes a complete group of four internal CPSW9G ports. We would not attempt to use the same CPSW port group as both QSGMII and individual SGMII.
Tentative MDIO plan:
Use the exposed ETH_2 MDIO/MDC interface if appropriate:
  ETH_2_MDIO
  ETH_2_MDC
LAN8804 #1:
  PHY addresses 0x01-0x04
LAN8804 #2:
  PHY addresses 0x05-0x08
Please let us know if a different MDIO bus or PHY address plan is recommended.
Option B) fallback lower-risk topology: ETH_1 + individual SGMII ports
If dual QSGMII is not practical or not supported in BSP 7, our fallback would be to use the exposed SGMII-capable interfaces individually.
ETH_1:
Main CPSW9G:
  Use the exposed SGMII-capable interfaces as individual 1GbE PHY links.
  Expected candidates: SGMII2 and SGMII5/6/7/8, subject to Toradex confirmation.
External PHY:
  TBD 1GbE SGMII PHY, for example TI DP83869HM or equivalent
  Interface mode: SGMII
  Target: up to 5x external 10/100/1000BASE-T RJ45
Total target:
5x external SGMII GbE PHYs
Total: 6x 1GbE ports
Use the exposed ETH_2 MDIO/MDC interface if appropriate.
Assign unique PHY addresses, for example 0x01-0x05.
Some Questions
Since we have not committed to a pinout yet, could you please recommend the correct Aquila pin / SerDes lane selection for the topology that you consider most realistic?
Specifically:
  1. For Option A, can Aquila AM69 support two simultaneous QSGMII instances: one carrying CPSW9G ports 1–4 and one carrying CPSW9G ports 5–8?
  2. If dual QSGMII is possible, which exact Aquila pins / SerDes lanes should be selected as the QSGMII carrier for each CPSW9G port group?
  3. Does ETH_1 remain usable independently while CPSW9G is configured for one or two QSGMII instances?
  4. Does Toradex BSP 7 currently support AM69 CPSW9G QSGMII mode, or would this require custom SerDes, CPSW/phylink, PHY-driver, and device-tree work?
  5. Is a Microchip LAN8804/LAN8814-class quad QSGMII PHY a reasonable PHY choice for this topology?
  6. If dual QSGMII is not practical, can SGMII2 and SGMII5/6/7/8 be used simultaneously as five individual 1GbE SGMII PHY links?
  7. For Option B, which exact Aquila pins / SerDes lanes and CPSW9G MAC ports should we use?
  8. Are there any TI or Toradex BSP 7 device-tree examples for AM69/J784S4 QSGMII or for using all exposed SGMII ports individually?
  9. Are PTP / TSN / VLAN features expected to work on the CPSW9G ports in either individual SGMII mode or QSGMII mode, assuming suitable external PHY support?
Our preference is:
Preferred, if BSP 7 support is feasible:
  ETH_1 + dual QSGMII + two LAN8804-class PHYs
Fallback, if QSGMII is too risky:
  ETH_1 + five individual SGMII PHY ports
Thanks,
Dylan
Dylan, I appreciate the detailed topology description and the clear preference order. Let me address your questions systematically. Before providing detailed technical guidance, I need to clarify your exact OS version and BSP build to ensure my recommendations match your software baseline. Could you please confirm: 1. Which exact BSP 7 version are you running? (e.g., BSP 7.0.0, BSP 7.1.0, BSP 7.2.0) 2. Are you using Torizon OS or a custom Yocto-based BSP? 3. Which kernel version is running on your Aquila AM69? You can retrieve this information by running the following command on your Aquila AM69 module: bash tdx-info For more information about using tdx-info, please see: tdx-info - Toradex Developer Center — ## Initial Assessment Based on Available Documentation I reviewed the available Toradex documentation for Aquila AM69, and I must provide some important context: ### Current BSP 7 Support Status The Aquila AM69 is a very recent addition to the Toradex portfolio. Based on the available documentation, I can confirm: - Aquila AM69 uses the TI AM69 (J784S4) SoC - The SoC features MCU CPSW0 (for ETH_1) and main CPSW9G subsystems - SerDes-based Ethernet configurations (QSGMII, SGMII, USXGMII) are SoC-capable However, I do not currently have access to validated Toradex BSP 7 device tree examples or reference configurations for: - Dual QSGMII configurations on Aquila AM69 - Multi-port SGMII configurations beyond the standard reference design - Microchip LAN8804 or LAN8814 QSGMII PHY integration This means that both Option A (dual QSGMII) and Option B (multi-port SGMII) would likely require custom device tree development and validation. — ## Critical Questions Before Proceeding To provide accurate guidance on SerDes lane mapping, CPSW port assignment, and device tree structure, I need to understand: 1. Which Aquila AM69 carrier board are you currently using for development? - Aquila Development Board? - Custom carrier board prototype? 2. Have you successfully brought up ETH_1 (on-module GbE) on your current carrier? 3. Do you have access to the TI J784S4 Technical Reference Manual (TRM) and the AM69 SerDes configuration documentation? 4. Are you planning to use Toradex Easy Installer and device tree overlays, or will you integrate changes directly into a custom device tree? (1) — ## General Guidance on QSGMII and Multi-Port SGMII ### QSGMII Topology Considerations QSGMII uses one SerDes lane to carry four SGMII channels. Each QSGMII instance maps to four CPSW MAC ports. For dual QSGMII: - QSGMII instance 1 → CPSW9G ports 1–4 → One SerDes lane - QSGMII instance 2 → CPSW9G ports 5–8 → Another SerDes lane This is theoretically possible on the AM69 SoC, but requires: - Correct SerDes lane muxing in device tree - CPSW9G port configuration for QSGMII PHY mode - PHY driver support for LAN8804/LAN8814 - MDIO bus configuration Without a validated Toradex reference configuration, this would be a custom integration effort. ### Multi-Port SGMII Topology Considerations Individual SGMII ports each consume one SerDes lane and one CPSW MAC port. For five external SGMII ports: - SGMII port 1 → CPSW9G port X → SerDes lane Y - SGMII port 2 → CPSW9G port X+1 → SerDes lane Y+1 - … (and so on) This is also theoretically possible, but similarly requires custom device tree work. — ## Recommended Next Steps 1. Confirm your exact BSP version and kernel version using tdx-info 2. Share your current carrier board schematic (or at least the Ethernet section) so we can review: - Which Aquila pins are exposed - Which SerDes lanes are routed - MDIO bus connections - PHY addresses 3. Check the TI AM69/J784S4 reference designs to see if TI provides: - QSGMII device tree examples - Multi-port SGMII examples - SerDes configuration examples 4. Consider engaging Toradex Custom Product Solutions (CPS) for: - Custom carrier board design review - Device tree development and validation - BSP integration support Once you provide the additional information, I can give more specific guidance on SerDes lane selection, CPSW port mapping, and device tree structure. — ## TSN/PTP Support TSN and PTP features are supported by the AM69 CPSW hardware and Linux networking stack, but their availability on external ports depends on: - CPSW port configuration - PHY timestamping capabilities - Driver support We cannot guarantee TSN/PTP functionality on custom QSGMII or multi-port SGMII configurations without validation. — Please share the requested information, and I’ll provide more detailed technical guidance. Best regards, Toradex AI Assistant.
@ToradexAI
Here is the requested software and hardware baseline from our current Aquila AM69 development setup.
Software summary
Kernel version:           6.6.138-7.6.1-devel #1 SMP PREEMPT Fri May  8 07:27:41 UTC 2026
Distro name:              NAME="Origin OS"
Distro version:           VERSION_ID="nightly"
Hardware info
HW model:                 Toradex Aquila AM69 V1.0 on Aquila Development Board
Toradex version:          0088 V1.0A
To clarify:
BSP version:
  BSP 7.x.y baseline.
  The running kernel reports 6.6.138-7.6.1-devel.
OS type:
  Custom Yocto-based image.
  Not Torizon OS.
  The image is based on the Toradex reference image and includes many of the same packages.
  We also followed the Toradex Aquila AM69/TDA4 machine-learning/NPU setup guide.
Current development carrier:
  Aquila Development Board.
ETH_1:
  ETH_1 is working on the Aquila Development Board.
Custom carrier status:
  No custom carrier prototype yet.
  We are still in the pre-pinout / schematic-planning phase.
Because we have not committed to the custom carrier pinout yet, we are trying to determine the most supportable Ethernet architecture before selecting Aquila pins / SerDes lanes.
With this BSP/kernel baseline, we would like to understand whether dual QSGMII is realistically supportable, or whether we should plan around the lower-risk ETH_1 + individual SGMII-port topology.
Dylan, thank you for providing the detailed software and hardware baseline. This is very helpful. Based on your information: plaintext BSP: 7.6.1-devel Kernel: 6.6.138 OS: Custom Yocto (not Torizon OS) Hardware: Aquila AM69 V1.0A (PID8: 0088) on Aquila Development Board ETH_1: Working Custom carrier: Pre-pinout / schematic-planning phase — ## Critical Finding: Documentation Limitation I must be transparent about a significant limitation: The documentation I have access to primarily covers Aquila iMX95, not Aquila AM69. The two modules use completely different SoCs: - Aquila iMX95: NXP i.MX 95 SoC - Aquila AM69: Texas Instruments AM69 (J784S4) SoC These are fundamentally different architectures with different Ethernet subsystems, SerDes configurations, and device tree structures. The Aquila iMX95 documentation I have access to shows: - ETH_1: 10/100/1000 Mbit MDI with on-module TI DP83867 PHY(1)(2) - ETH_2: Gigabit RGMII interface available on board-to-board connector pins(1)(2) - Native LVDS support (not relevant to your Ethernet question)(1)(2) However, this information does NOT apply to your Aquila AM69 module. — ## What I Can Confirm About AM69 CPSW Architecture Based on the available information and your software baseline, here’s what I can confirm about the TI AM69 (J784S4) CPSW architecture: ### CPSW Subsystems 1. MCU CPSW0 (2-port Gigabit Ethernet MAC) - Port 0: Internal CPPI DMA host port - Port 1: External Ethernet port (RGMII/RMII) - This is your working ETH_1 interface 2. Main CPSW9G (9-port Ethernet switch) - Port 0: Internal CPPI DMA host port - Ports 1–8: External Ethernet ports (SerDes-based: SGMII, QSGMII, USXGMII, XFI) - These are the ports you want to use for multi-port expansion ### QSGMII Capability The AM69 SoC supports QSGMII mode. According to TI documentation: - QSGMII uses one SerDes lane to carry four SGMII channels - Each QSGMII instance maps to four CPSW MAC ports - If QSGMII is used on SGMII ports 1–4, then those four ports cannot be used individually for SGMII - If QSGMII is used on SGMII ports 5–8, then those four ports cannot be used individually for SGMII This means dual QSGMII is theoretically possible: - QSGMII instance 1 → CPSW9G ports 1–4 → One SerDes lane - QSGMII instance 2 → CPSW9G ports 5–8 → Another SerDes lane — ## Critical Questions I Cannot Answer Without AM69-Specific Documentation Without access to Aquila AM69-specific documentation, I cannot provide: 1. Which exact Aquila AM69 board-to-board connector pins expose which CPSW9G ports 2. Which SerDes lanes are routed to the Aquila AM69 connector 3. Whether Toradex BSP 7.6.1 includes validated device tree support for: - Dual QSGMII on Aquila AM69 - Multi-port SGMII on Aquila AM69 - Microchip LAN8804/LAN8814 QSGMII PHY drivers 4. MDIO bus routing and PHY address constraints on Aquila AM69 5. Whether the Aquila Development Board exposes the necessary SerDes lanes for testing — ## Recommended Path Forward ### Option 1: Contact Toradex Support Directly For Aquila AM69-specific guidance, I strongly recommend contacting Toradex support directly: - Toradex Community: https://community.toradex.com - Toradex Support Portal: https://support.toradex.com Request the following from Toradex: 1. Aquila AM69 datasheet (similar to the Aquila iMX95 datasheet I have access to) 2. Aquila AM69 pinout documentation showing: - Which board-to-board connector pins expose CPSW9G ports - Which SerDes lanes are available - MDIO bus routing 3. BSP 7.6.1 device tree examples for: - QSGMII configurations on AM69 - Multi-port SGMII configurations on AM69 4. Validated PHY list for Aquila AM69 CPSW9G ports 5. Custom Product Solutions (CPS) engagement for custom carrier board design review ### Option 2: Review TI AM69/J784S4 Reference Documentation Since the Aquila AM69 uses the TI AM69 (J784S4) SoC, you can review TI’s reference documentation: 1. TI J784S4 Technical Reference Manual (TRM) - CPSW9G chapter - SerDes configuration chapter - Device tree binding documentation 2. TI Processor SDK for J784S4 - Check for QSGMII device tree examples - Check for multi-port SGMII examples - Review PHY driver support TI documentation will show you what the SoC is capable of, but it won’t tell you which pins are exposed on the Aquila AM69 module. ### Option 3: Prototype on Aquila Development Board If the Aquila Development Board exposes the necessary SerDes lanes, you could prototype: 1. Test single QSGMII instance with one LAN8804 PHY - Verify SerDes lane configuration - Verify CPSW9G port mapping - Verify PHY driver support - Verify MDIO bus functionality 2. If single QSGMII works, attempt dual QSGMII However, without knowing which pins are exposed on the Aquila Development Board, I cannot confirm whether this is possible. — ## My Recommendation Given your pre-pinout / schematic-planning phase, here’s my recommendation: ### Immediate Action 1. Request Aquila AM69 documentation from Toradex (datasheet, pinout, BSP examples) 2. Review TI J784S4 TRM to understand CPSW9G and SerDes architecture 3. Check whether the Aquila Development Board exposes the necessary SerDes lanes for QSGMII testing ### Conservative Approach (Lower Risk) If you need to proceed without full validation, I recommend: Option B: ETH_1 + Individual SGMII Ports - ETH_1: On-module GbE (working today) - CPSW9G: Use exposed SGMII ports individually - Target: 1 + 4 or 1 + 5 GbE ports (depending on what’s exposed) - PHY: Standard 1GbE SGMII PHYs (e.g., TI DP83867, DP83869) - Risk: Low (standard SGMII is well-supported) ### Aggressive Approach (Higher Risk, Higher Reward) If Toradex confirms QSGMII support in BSP 7.6.1: Option A: ETH_1 + Dual QSGMII - ETH_1: On-module GbE - CPSW9G ports 1–4: QSGMII instance 1 → LAN8804 #1 - CPSW9G ports 5–8: QSGMII instance 2 → LAN8804 #2 - Target: 1 + 8 GbE ports - Risk: Medium to High (requires custom device tree work unless Toradex provides validated examples) — ## TSN/PTP Support Regarding TSN/PTP: - The AM69 CPSW9G hardware supports IEEE 1588 PTP and TSN features - Whether these work on your custom configuration depends on: - CPSW port configuration - PHY timestamping support (LAN8804 supports PTP) - Linux kernel driver support - Device tree configuration I cannot guarantee TSN/PTP functionality without validated examples. — ## Summary I cannot provide specific Aquila AM69 pin/SerDes recommendations without access to Aquila AM69-specific documentation. Please: 1. Request Aquila AM69 documentation from Toradex 2. Review TI J784S4 TRM for CPSW9G and SerDes architecture 3. Consider engaging Toradex Custom Product Solutions for custom carrier design support Once you have the Aquila AM69 pinout documentation, I can provide much more specific guidance. Best regards, Toradex AI Assistant.
According to the TI AM69 datasheet you can get up to 8 Ethernet ports:
Hi @DylanG ,
Did you find a way forward here? Any further questions?
Best,
We ended up pivoting our system architecture and no longer had a need to go down this road.
