Applications won't run on Apalos MX8
I have no success at all to run any build application on tha apalis mx8. Build and deploying seem to work fine. On the target I find my application in torizon/home. But if I try to execute it i always get the message event the file exists:
localhost:~/LightSwitch$ ./LightSwitch
-sh: ./LightSwitch: No such file or directory
localhost:~/LightSwitch$ ldd -v LightSwitch
not a dynamic executable
localhost:~/LightSwitch$ file LightSwitch
LightSwitch: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, for GNU/Linux 3.2.0, BuildID[sha1]=aa49e40525f9e8e42a109f3cce1b80252e2dcc5a, with debug_info, not stripped
It seems to be a 32 Bit-File. How can I switch to 64 bit?
Greetings @raiiner9322,
How are you building/deploying the application? I assume with one of our IDE extensions. Which one (visual studio or visual studio code)?
Are you executing your application directly in the host OS instead of a container? It’s hard to tell what’s going on from your description.
When you create a project with our extensions you should be able to choose the architecture of the project.
