ApolloX tcb project: rename a folder changes docker-compose.yml
I notice a strange thing when I work with a TorizonCore Builder project in ApolloX (on WSL - I didn’t try in Linux).
Below you can see that if I rename the folder storage, the file docker-compose.yml is changed unexpectedly.
It seems that the last line is moved (appended) to the previous line (it seems that the end-of-line is removed).
ezgif-3-5825cbc568
And as a consequence, the YAML parser starts complaining about malformed yaml (and it’s right).
@matheus.castello can you double check?
Hey @vix,
yeah, this was strange. The extension need to refresh the file to check changes on the workspace, so linter can update the tips. But it should not make these weird changes. I will take a look on it. Thanks for the report, I will notify you here with news.
Hey @vix
the TorizonCore Builder extension was updated to the version 0.0.9, and this issue should be fixed.
I confirm it has been fixed.
