We have the Toradex CSI Camera Module 5MP OV5640 plugged into an Ixora Carrier Board V1.1A, with ubuntu 14.04 and jetpack installed on apalis tk1.
We followed the instruction here
but we keep stuck at the line: modprobe tegra_camera, it returns “the device or resource is busy”
Does anyone familiar with this problem?
Yes, the issue is that Ubuntu by default already loads an alternate camera stack resulting in the following error:
root@tegra-ubuntu:~# modprobe tegra_camera
[ 51.914899] Error: Driver 'vi' is already registered, aborting...
modprobe: ERROR: could not insert 'tegra_camera': Device or resource busy
The loaded modules may be queried as follows:
root@tegra-ubuntu:~# lsmod
Module Size Used by
ov5640 7636 0
videobuf2_dma_contig 10124 0
rfcomm 32943 0
bnep 9791 2
bluetooth 267907 10 bnep,rfcomm
apalis_tk1_k20 9273 0
nvhost_vi 2937 0
Just un-load resp. module before proceeding:
root@tegra-ubuntu:~# rmmod nvhost_vi
Now the V4L2 stack should load fine (ignore the errors resulting from alternate sensors being probed):
[ 89.125245] imx135_v4l2 2-0010: Failed to get regulator vana
[ 89.147032] ar0330_v4l2 2-0018: ar0330_regulator_get vdig ERR: -517
[ 89.156832] ar0330_v4l2 2-0018: ar0330_regulator_get vana ERR: -517
[ 89.163239] ar0330_v4l2 2-0018: ar0330_regulator_get vif ERR: -517
[ 89.171770] [ar0330]: failed to read sensor id
[ 89.176600] [ar0330]: fail to read out sensor ID.
[ 89.420536] i2c_wr:write reg error:reg=4,val=0
[ 89.426763] i2c_wr:write reg error:reg=8502,val=0
[ 89.433410] tc358743_write_edid:write reg error:reg=8c00,val=8
[ 89.441338] tc358743_probe: Fail to write EDID to tc35874!
[ 89.446979] i2c_wr:write reg error:reg=8544,val=0
[ 89.952154] i2c_wr:write reg error:reg=8544,val=10
[ 89.964104] i2c_wr:write reg error:reg=4,val=0
[ 89.971885] i2c_wr:write reg error:reg=8502,val=0
[ 89.977119] tc358743_write_edid:write reg error:reg=8c00,val=8
[ 89.983311] tc358743_probe: Fail to write EDID to tc35874!
[ 89.989304] i2c_wr:write reg error:reg=8544,val=0
[ 90.495049] i2c_wr:write reg error:reg=8544,val=10
[ 90.570741] ar0261_v4l2 2-0036: ar0261_regulator_get vdig ERR: -517
[ 90.577444] ar0261_v4l2 2-0036: ar0261_regulator_get vana ERR: -517
[ 90.583823] ar0261_v4l2 2-0036: ar0261_regulator_get vif ERR: -517
[ 90.590044] ar0261_v4l2 2-0036: ar0261_regulator_get avdd_af1_cam ERR: -517
[ 90.598673] [ar0261]: failed to read sensor id
[ 90.603567] [ar0261]: fail to read out sensor ID.
And all should work as expected:
root@tegra-ubuntu:~# gst-launch-0.10 v4l2src queue-size=1 ! 'video/x-raw-yuv,format=(fourcc)UYVY,width=640,height=480' ! xvimagesink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
WARNING: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not get parameters on device '/dev/video0'
Additional debug info:
v4l2src_calls.c(235): gst_v4l2src_set_capture (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
system error: Inappropriate ioctl for device
Setting pipeline to PLAYING ...
New clock: GstSystemClock
I did follow the instruction you gave, it works the first time, but for second time “lsmode” return this
Module Size Used by
ar0261_v4l2 7989 0
soc_camera_platform 2124 1
adv7280 4178 1
tc358743 6755 0
ov5640 7636 0
ap1302 4680 0
ar0330_v4l2 7365 0
imx135_v4l2 12475 0
tegra_camera 23209 0
videobuf2_dma_contig 10356 1 tegra_camera
joydev 8235 0
bnep 9919 2
rfcomm 32999 0
bluetooth 268603 10 bnep,rfcomm
rfkill 11327 3 bluetooth
and then
root@tegra-ubuntu:/home/ubuntu# gst-launch-0.10 v4l2src queue-size=1 ! 'video/x-raw-yuv,format=(fourcc)UYVY,width=640,height=480' ! xvimagesink
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not negotiate format
gstbasesrc.c(2830): gst_base_src_start (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Check your filtered caps, if any
Setting pipeline to NULL ...
Freeing pipeline ...
doesn’t work, what could be the trouble?
What exact hardware and software versions of things are you talking about? I recommend using BSP 2.7b5 or 2.8b1 as there were quite some camera fixed done lately.
