I’m trying to get the ethernet connected to PCIe to work, but it fails.
I’m using the Apalis-TK1_LXDE-Image_2.8b2.97-20180331.tar.bz2 from Index of /Colibri/Linux/Images
I have attached the bootlog:
link text
link text
Hi
Could you provide the exact hardware version of your module? Which carrier board are you using?
What is the output of lspci
Ok it’s running now. The problem was that one of the following kernel commandline options was missing:
igb_mac=00:14:2d:2c:d5:d3 lp0_vec=2064@0xf46ff000 core_edp_mv=1150 core_edp_ma=4000 usb_port_owner_info=2 lane_owner_info=6 emc_max_dvfs=0 pcie_aspm=off user
Ok, thanks for the feedback. Which carrier board are you using?
Currently I’m using the Ixora v1.1 as well as a own designed custom Board.
On the custom board there still persist an issues for PCIe Port 0 (reset), while Port 1 works.
We have already contacted your support and waiting for an answer.
I will post the results later.
Regards
What do you mean by Port 0 and Port 1?
