I have an Apalis T30 which cannot be flashed through SDCard (do not know why) and the USB is also failing (EHCI timed out on TD - token=0x8008d80 many times…). Therefore, I am trying to flash it over ethernet with TFTP. However, I new problem is appearing.
After setting the board ip and server ip with in the UBoot with:
stenv ipaddr 192.168.1.107
(a random, free IP)
setenv serverip 192.168.1.171
Doing ping ${serverip}
outputs the following:
Apalis T30 # ping ${serverip}
e1000: e1000#0: ERROR: Valid Link not detected
Using e1000#0 device
ping failed; host 192.168.1.171 is not alive
Therefore I have no more ways to flash the Apalis. Any help with the USB or Ethernet is very welcome.
EDIT: It seems that the USB problem was just a hardware problem with the pen drive used. In any case I would like to debug the ethernet issue as I think it more convenient for my case.
