I am trying to get mainline 4.14 kernel running on Apalis T30 using bitbake with a poky-tiny setup (initramfs)
I’ve cloned distro poky-tiny to my own layer my-poky-tiny. I’ve also cloned apalis-t30 machine, and created a apalis-t30-mainline machine. I’ve also cloned recipes meta-toradex-tezi/recipes-bsp/u-boot and meta-toradex-tezi/recipes-kernel to my own layer.
The kernel, cpio file system, and u-boot all build. I suspect I need to either build a .dtb or similar to get the kernel to boot, or I haven’t used the correct LOADADDR or similar. The only .dtb I can find is here, but I don’t think this is the right one?:
Also, I have a tftp server that I want to boot the desired image. Does this look correct, provided that the addresses are correct? I am using pre-setup hard coded IP’s - the download is successful. I don’t really want to use USB or even flash an image each time, and the image is less than 10MB.
I should have been more careful cutting and pasting while editing apalis-t30-mainline.conf machine. I used the wrong device tree from the TK1. The correct one is for what I am trying to do is:
KERNEL_DEVICETREE += “tegra30-apalis-eval.dtb”
The kernel now boots, although I’ll have to correct the root file system. That shouldn’t be too hard though.
That’s the device tree from U-Boot which at least as of today is not quite the same as the Linux one. Would be the end goal in the future though I guess.
Concerning your TFTP setup while it looks fine we usually configure the whole thing automatically via DHCP as outlined here:
