Hey guys~
My image update manner for Apalis iMX8QM SOM / Ixora 1.1B is very pre-historic mechanism. ^^
Just looping up recovery pin hole JP4 on Ixora 1,1B board with a line, and then connecting the board with Linux PC through USB OTG port (bottom of the Ixora). Of course JP2 is open.
Then booting is stopped and I can manually trigger booting from a command line through “uuu .” with toradex easy installer image. Probably you will catch up what I will usually do for the image update. Yes… copying finakl image into USB stick and hook it into the Apalis and installing through easy installer… Wow nice!! This might be burdensome work but this is so clear and steppable way preferred by aged person like me. ^^
I have a question. After some of trials, actually from several days ago, my Apalis SOM doesn’t stop booting even with looping recovery pin holes at JP4 and hooking up USB OTG connection between the board and Linux PC. what’s wrong? What treatment I need to do to go back to my past peaceful status. Now I cannot update my Apalis board. Please help me.
All through up happy weekend Guys~
Todd.
[ 8048.323991] usb 1-1: new high-speed USB device number 34 using xhci_hcd
[ 8048.474211] usb 1-1: New USB device found, idVendor=1b67, idProduct=4025, bcdDevice= 4.01
[ 8048.474217] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8048.474220] usb 1-1: Product: facedemo-iMX8
[ 8048.474223] usb 1-1: Manufacturer: Toradex
[ 8048.474226] usb 1-1: SerialNumber: 06540899
[ 8048.494507] rndis_host 1-1:1.0 eth1: register 'rndis_host' at usb-0000:00:14.0-1, RNDIS device, 00:14:2d:ff:ff:fe
This is the “dmesg” footprint came out of the OTG port from my Apalis SOM. Actually it doesn’t look same as I have seen when everything was good. “facedemo-iMX8” is a product name I used for my image build. I think it shouldn’t be related to USB hotplugging… Hmm…
