Apalis iMX8QM HDMI output issue
Dear Support Team,
We are testing Apalis iMX8QM V1.1B/Ixora V1.1A hardware with Ycoto Linux reference multimedia image 5.0 BSP, and found that HDMI output doesn’t work normally under linux (the display is a 13.3 inch HDMI display with up to 4K resolution and works well with toradex easy installer 2.0b6 and former BSP 3.0), no signal output to display, and the dmesg is as below -
root@apalis-imx8:~# dmesg |grep drm
[    1.967371] imx-drm display-subsystem: parent device of /bus@57240000/ldb@572410e0/lvds-channel@0 is e
[    2.836444] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.843089] [drm] No driver support for vblank timestamp query.
[    2.849099] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[    2.857246] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[    2.865542] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[    2.872931] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[    2.880316] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[    2.887694] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[    2.897161] [drm] Started firmware!
[    2.909837] [drm] HDP FW Version - ver 26098 verlib 20560
[    2.922685] imx-drm display-subsystem: bound 56268000.hdmi (ops cdns_mhdp_imx_ops)
[    2.930598] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[    2.976695] [drm] Mode: 1920x1080p148500
[    3.003427] [drm] Pixel clock: 148500 KHz, character clock: 185625, bpc is 10-bit.
[    3.003432] [drm] Pixel clk (148500 KHz) not supported, color depth (10-bit)
[    3.003449] [drm:cdns_hdmi_phy_set_imx8qm] *ERROR* failed to set phy pclock
[    3.003451] [drm] Sink Not Support SCDC
[    3.004979] [drm] No vendor infoframe
[    3.154538] imx-drm display-subsystem: fb0: imx-drmdrmfb frame buffer device
Have tried with Ycoto linux reference multimedia monthly release 5.0.0-devel-202009+build.2 and latest 5.0.0-build.3 on 20201006, both have same issue.
Also have tried another 2 model Dell desktop 1080P monitor, the first one is an old model E2211H, dmesg shows as below and seems no issue, but the display has no signal with “input timing is not supported …” prompt message on the screen.
[    1.965534] imx-drm display-subsystem: parent device of /bus@57240000/ldb@572410e0/lvds-channel@0 is e
[    2.856440] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.863090] [drm] No driver support for vblank timestamp query.
[    2.869119] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[    2.877290] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[    2.885732] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[    2.893271] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[    2.900783] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[    2.908301] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[    2.917906] [drm] Started firmware!
[    2.930644] [drm] HDP FW Version - ver 26098 verlib 20560
[    2.943817] imx-drm display-subsystem: bound 56268000.hdmi (ops cdns_mhdp_imx_ops)
[    2.951777] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[    2.984505] [drm] Mode: 1920x1080p148500
[    3.011413] [drm] Pixel clock: 148500 KHz, character clock: 148500, bpc is 8-bit.
[    3.011418] [drm] VCO frequency is 2970000 KHz
[    3.076433] [drm] Sink Not Support SCDC
[    3.077961] [drm] No vendor infoframe
[    3.251897] imx-drm display-subsystem: fb0: imx-drmdrmfb frame buffer device
root@apalis-imx8:~# dmesg |grep hdmi
[    2.921538] cdns-mhdp-imx 56268000.hdmi: Direct firmware load for hdmitxfw.bin failed with error -2
[    2.936375] cdns-mhdp-imx 56268000.hdmi: lane-mapping 0x93
[    2.974303] cdns-mhdp-imx 56268000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[    9.730909] cdns-mhdp-imx 56268000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
the second one is a newer model Dell P2219H, it works well when plugging to device before booting, but if hot plugging the HDMI connector after booting, the screen output will freezing, mouse pointer also no response.
Thanks and Best Regards
Simon
Those dmesg snippets are pretty much useless please include full console outputs as a text files.
Please note that this former monthly release is no longer supported and needs upgrading to a later quarterly or monthly release.
Hi Marcel,
please find full console output in the attachment, the test is based on tdxref-oe-prod-horw/dunfell-5.x.y/release/3/apalis-imx8/tdx-xwayland/tdx-reference-multimedia-image/teziimage/Apalis-iMX8_Reference-Multimedia-Image-Tezi_5.0.0+build.3 image.link text
Hi, I am having the same problem with an Apalis IMX8 Quad Plus / Ixora 1.2. The HDMI screen works for the easy installer, but shows nothing when booting the TDX reference multimedia image.
Was this problem resolved somehow?
Thanks and best regards,
Paul
