Hey there, I need to set up a toradex apalis iMX8, version unknown. When I first started it up, Torizon was installed, but nothing else. Using several guides I’ve found online I found several ways to get easy installer, but it didn’t work.
Here’s how I did it: First I put it in recovery mode, then I use the host pc and the recovery tool.
The output is a progress bar that counts up to 100% and then nothing else happens…
Any ideas?
Hi @NicolasPucelage !
Could you please share the exact module and version? You can find it on the sticker on the module.
