Hi everyone,
I am building my own Boot2Qt image based on this manifest https://code.qt.io/cgit/yocto/boot2qt-manifest.git/tree/v5.15.8-lts.xml
On hardware side, I am using an Apalis-iMX8QP 2GB WB V1.0B.
When running my image, it seems that EDID is not working as I am always getting 1024x768 resolution (on 1080p monitors as well as 800p monitors)
After further investigation, I managed to make it work by applying this command in U-Boot
setenv fdtfile "imx8qm-apalis-eval.dtb"
(By default it is “imx8qp-apalis-v1.1-eval.dtb”)
and then booting my device. But this is not persistant even by applying saveenv since there is another env variable (preboot), that is overriding fdtfile at boot. Of course I could override preboot instead but writing env var manually for every device does not seem’s “producion ready”.
So is there a way to solve my problem when building my image with yocto? I already have a custom meta-layer to add some packet to Qt so I’d like to use it to change my default device tree.
Tanks for your help!
