Apalis iMX6 u-boot usb load crash - Toradex 3.0 BSP
Hi, we are using the Toradex BSP as base for our own distribution. After upgrading to LinuxImage-3.0 with the 2019.07 U-boot USB reading broke on Apalis iMX6. Are there any known bugs related to that?
I attached an u-boot log
U-Boot 2019.07-3.0.2+ge1cbe8c (Nov 07 2019 - 15:44:12 +0000)
CPU:   Freescale i.MX6Q rev1.5 at 792MHz
CPU:   Industrial temperature grade (-40C to 105C) at 39C
Reset cause: WDOG
DRAM:  2 GiB
PMIC:  device id: 0x10, revision id: 0x21, programmed
MMC:   FSL_SDHC: 1, FSL_SDHC: 2, FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
Model: Toradex Apalis iMX6 Quad 2GB IT V1.1C, Serial# 05184994
Net:   using PHY at 7
FEC [PRIME]
Apalis iMX6 # usb start
starting USB...
Bus usb@2184000: USB EHCI 1.00
Bus usb@2184200: USB EHCI 1.00
scanning bus usb@2184000 for devices... 1 USB Device(s) found
scanning bus usb@2184200 for devices... 3 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
       scanning usb for ethernet devices... 0 Ethernet Device(s) found
Apalis iMX6 # load usb 0:1 ${loadaddr} flash_mmc.img
data abort
pc : [<8efb3096>]          lr : [<8efb2b19>]
reloc pc : [<17834096>]    lr : [<17833b19>]
sp : 8cf73d80  ip : 00000003     fp : 00000000
r10: 8cf83330  r9 : 8cf7eea8     r8 : 00000001
r7 : 8cf833f8  r6 : 8bf72040     r5 : 8cf73da8  r4 : 00000020
r3 : 00000066  r2 : 8bf720a3     r1 : 8cf83464  r0 : 8bf7209f
Flags: nzCv  IRQs off  FIQs off  Mode SVC_32
Code: 4630ff4d 81f0e8bd e7d84606 bf082b2f (f822235c)
Resetting CPU ...
resetting ...
Industrial temperature grade DDR3 timings.
Trying to boot from MMC1
Reset cause: WDOG
Anton
HI @iSchluff and Welcome to the Toradex Community!
Starting with Bsp 3.0, we are only supporting distro_boot for the boot process of the module. Additionally we dropped the support of legacy update Procedure.
Being said that, I can reproduce this issue on side.
We will look into this issue and come back soon to you.
Hi Jaski,
We are aware that the upgrade process and old-style boot are unsupported as of 3.0 and are in the process of migrating away from it.
Thanks for looking into the Issue.
Anton
Hi Anton,
Thanks for your Input.
You are welcome.
I will come back to you once I got more Information about this issue.
Hello @iSchluff,
The fix for this issue is here http://www.toradex.com/community/answers/42144/view.html
Hope it helps!
Igor
Hi @igor.tx,
Thanks a lot, that was it.
I guess it would be useful to have that patch in meta-toradex-nxp.
Anton
Hi
You are welcome.
This patch will be included in our next release.
