I am designing a board which uses 4x SPI ports. However, I cannot find the PIN ECSPI4_MOSI
neither in the Pinout Designer nor in the Apalis imx6 datasheet.
Is this a documentation issue or is the ECSPI4 not usable?
SPI4 is not available. According to Apalis iMX6 to datasheet:
The i.MX 6 Dual and Quad SoC have 5 SPI controllers (in the reference manual called Enhanced
Configurable SPI, ECSPI) of which 3 can be accessed at the module edge connector.
You can use espi1, espi2 and espi5.
Thanks for the answer. The feature overview should be changed!
overview clearly states: SPI 4x.
Which confusing, because you can only use 3 SPI-Ports.
We will update overview page. Thank you.
