Hello
I use the Apalis iMX6 Quad Module and I have a problem with the usage of a Newhaven Display. I’ve tried to use it with the RGB24 parallel connector of the Ixora Board. I’m using the generic display adapter provided by Toradex to connect the third party display.
I adapted the Image provided by Toradex. To be more precise i exchanged the filesystem built by openEmbedded framework through a generic Debian filesystem. I’ve already done some additional Kernel configuration. But basically I’m using the Kernel configured by apalis_imx6_defconfig provided by Toradex.
In addition I’m using the Device-Tree imx6q-apalis-ixora-v1.1.dts without any modification.
At first I’ve tried to set the environment variable in u-boot to:
setenv vidargs 'mxc_hdmi.only_cea=0 video=mxcfb0:dev=lcd,800x480M@60,if=RGB24
video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=32M'
But the display stays black.
Afterwards I’ve tried to add the exact display timings to the lcd driver “fsl,lcd” in the toradex kernel. So I’ve created a new entry;
/* 800x480 @ 65 Hz , pixel clk @ 33 MHz */ /* 30303 ps*/
"newhaven1", 65, 800, 480, 30303,
.left_margin = 128,
.right_margin = 40,
.hsync_len = 48,
.upper_margin = 45,
.lower_margin = 13,
.vsync_len = 3,
.sync = 0,
.vmode = FB_VMODE_NONINTERLACED,
.flag = 0,}
After that I compiled the kernel successfully and added it to the image. In the image I changed the environment variable for the display in uEnv.txt to:
setenv vidargs 'mxc_hdmi.only_cea=0 video=mxcfb0:dev=lcd,newhaven1,if=RGB24
Then I’ve flashed the board with the Toradex EasyInstaller. When I check the FrameBuffer configuration with fbset I get the timings I’ve added in the driver, but the display doesn’t work. The screen lights up for a short time while booting. Afterwards the display is just black with the backlight on.
Has anyone an idea how to fix this problem?
Here are the exact version of the used tools:
Versions:
Easy Installer
apalis-imx6_toradexeasyinstaller_1.8-20181019
Apalis-iMX6_LXDE-Image_2.8b5.156-20181228
Toolchain
gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf
Kernel 2.8b
toradex_4.9-2.3.x-imx Linux kernel : 4.9.144
Device Tree
imx6q-apalis-ixora-v1.1.dtb (from imx6q-apalis-ixora-v1.1.dts)
UBoot 2.8b
2016.11-toradex
Filesystem
Debian 9.8
Display
NHD-5.0-800480MB-ATXL-CTP
https://www.newhavendisplay.com/nhd50800480mbatxlctp-p-9611.html
