Yes, I’ve asked them via email.The answer is as follows.
Our 12.3” product has no Back Porch and no Front Porch.
Meaning they really do not accept any? The datasheet we got from you suggests otherwise.
The reason is that the Timing Controller in our panel is not using H-sync and V-sync and Back and Front Porch just describe the timing between data and H-Sync and V-Sync.
Yes, but any sane panel will just ignore any such rather than failing. Or is it such an insane panel we fear it is? Then you are basically screwed.
In case of AA123AD11 only DENA is used for synchronization (horizontally and vertically).
What exactly do they mean by this? Usually DENA is used to gate valid pixel data for every line. No less and no more. What exactly do they expect their DENA to be doing?
Below is a shortcut of datasheet of AA121AD11 page 26/27. There is no more timing information available and needed.
But why exactly is it still not working? How about the encoding of pixel data which their datasheet is very unclear about?
Two questions come to mind at this point. 1- Should we leave these values empty?
I tried this, but when I left it empty I got an error, but I’m not quite sure.
I don’t think this is possible.
2- Should these values be 0?
The manufacturer says the product has no Porch. In this case If 0 has a meaning, would it be correct to write 0 to these values?
I’m not even sure this is possible as usually those engines writing out pixel data have certain restrictions.
Thanks.
You are very welcome.
