Apalis IMX6 loading .bin from SD using go Command
Hello
I am trying to load a binary file from SD Card using the go Command.
when I type ‘go’ then ‘filename.bin’ I get 'Starting application at 0x00000000… and nothing happens afterwards.
When I type ‘go’ and then any start address of the usdhc 1,2,3, or 4 i.e:0219_C000… eMMC starts loading linux.
If the I put the address into brackets ‘{}’, I get Starting application at 0x00000000… and nothing happens afterwards again.
Would you please help me loading this using go command?
Thanks.
