Apalis IMX6 cannot enter recovery mode
i have been working with Apalis imx6 for some time now. i have 3 apalis imx6 device. However, i have encountered a problem. When i connect the Apalis imx6 as usual, the screen does not appear and it just waits. Even though I have performed the necessary steps for recovery mode, the situation remains unchanged. When insert another card(apalis), it goes recovery mode, but this doesn’t happen with this card, and it happened suddenly. And I’m writing this because I experienced the same thing with my second card.
Hardware i use:
Apalis IMX6Q 2GB IT V1.1D
Ixora Carrier Board
I would be happy if you could solve the problem.
Hello! Thank you for your detailed description of the issue.
From your symptoms—no display output, failure to enter recovery mode, and the problem occurring suddenly on multiple Apalis iMX6Q modules—it appears you are experiencing a hardware-level issue similar to documented failures.
Here are some points to consider:
1. Typical Symptoms and Causes
  • No HDMI output, only one LED lights up, no USB device detected in recovery mode: These are known failure patterns on some modules.
  • Root Cause: In several cases, investigation traced the issue to a missing voltage rail—specifically +V3.0_RTC. When this voltage rail is missing, the SoC cannot signal the PMIC to begin power-up. This often results in the symptoms you described.
  • Typical reason: This can sometimes happen if, while shorting the recovery pins (JP4, pins 2 and 3 on the Ixora board), the short bridges to another part of the board, causing unintentional hardware damage.
2. Double-check Recovery Mode Procedure
Just for reference, here is the correct recovery procedure for the Ixora + Apalis iMX6:
  1. Power off the board.
  2. Short JP4 pins 2 and 3 with a jumper.
  3. Power on the board. Only after powering on, remove the jumper.
    (See the Ixora Carrier Board Recovery Instructions for details.)
3. Documented Community Cases
Your situation matches previous documented incidents, where modules became unresponsive due to hardware failure, likely linked to power rail faults.
4. Next Steps
Given that the problem persists even after following the correct recovery mode steps—especially if other modules still work—it is likely a hardware fault on the affected modules.
Unfortunately, if the voltage rail is failing, the module may not be recoverable through standard software methods.
If you have any other software or configuration-related questions, or want help verifying your recovery procedure, feel free to ask!
Hey, @Tolga,
Are you able to connect to the board via serial? If you can, can you tell me the output? There could be an error during the boot process.
Also, there are some other things that could help us uncover the issue:
  • When did this start happening? Were you able to enter recovery mode with this module/board before?
  • You said you performed the necessary steps for entering recovery mode, and the screen does not appear. Did you follow this guide? I suppose you are trying to load Tezi into the board and it’s not working. Does the loading process fail, or does it succeed and then nothing appears on the screen?
First of all, I apologize for the late response, I couldn’t write earlier since I have been busy with my ongoing work.
Yes, I am able to connect via the serial port. However, since I am a new user, I am not able to share the logs of the working and non-working boards.
  • Previously, I was able to enter recovery mode on the same board. At the moment, on the same development board, I can still enter recovery mode with other processor boards. The issues started after flashing the image using “Toradex Easy Installer” on the boards.
  • Yes, I followed all the steps correctly. Since it does not enter recovery mode, the OS does not run at all.
Additionally, on another board, I do not receive any messages from the serial interface, and no display output appears — it just stays idle.
TY
Hey, @Tolga,
I’m a bit confused, you said you’re not able to share the logs since you’re a beginner, but here you said:
This is just a guess, but I presume that you are trying to read the serial logs from the same port you are using to flash the Toradex Easy Installer. Take a look at the datasheet for the Ixora Carrier Board. The UART debug interface is at the X22 connector, which is different from the port you use to flash the Toradex Easy Installer image:
After connecting the X22 connector to your host machine, you can follow the page about how to connect to the board via serial. If your board doesn’t boot there should be at least some helpful information from U-Boot.
Additionally, can you tell me the exact steps you are following to flash your image? Even if they’re the same steps we recommend in our guide, if you tell me the process you are following step by step it will clear the confusion and help pinpoint the problem. Also specify the versions of the tools you are using. Are you using the latest Toradex Easy Installer version? What image exactly are you installing to the board?
First of all, I have multiple Apalis iMX6 boards. One of them is working properly, but the other two are faulty. Both of the faulty boards do not enter recovery mode; however, when I connect them to the serial port, I can get output from one of them, but from the other I cannot get any output at all. I made the serial connection through X22 as shown, and I verified the correctness of this line on a working board.
The procedure I followed to enter recovery mode:
  • I removed the JP2 jumper,
  • Connected USB to the X9 connector,
  • Shorted pins 1-2 on JP4,
  • And powered up the board.
And I did all of this by following this reference.
After entering recovery mode, I run Tezi on the terminal (.\recovery-windows.bat).
Then, from the interface that comes up, I select my image and install it.
The versions of the firmware I used are:
Tezi: Apalis-iMX6_ToradexEasyInstaller_5.7.2+build.14
Image: Linux apalis-imx-11473594 5.4.192-5.7.6
Tolga YILMAZ
Embedded Software Engineer
Hey @Tolga,
Your procedure to enter recovery mode looks correct, however, your version of the Toradex Easy Installer is heavily outdated. Please download an up-to-date version and use it instead. Also, where does the image you installed come from? We recommend either of the following:
  • Install one of the images from our feed (look for either a Torizon OS image or “Toradex Embedded Linux Reference…”)
  • Download one of our images directly and load it into Toradex Easy Installer
About the two faulty boards, please send the serial output of the one with the working interface. It should be the U-Boot interface.
As for the other board, it’s strange that you don’t see any output, if the board does not boot there should be at least the U-Boot interface. Did you do anything different at all when you tried to flash this board? Does this board show any other different behavior from the other ones?
I apologize for the delayed response. It was due to internal company planning issues.
Easy Installer version: Understood, I will download the latest version from the link you provided and use that going forward instead of the outdated one.
Image source: The image was not custom-built. After flashing with Easy Installer, a selection interface appeared on the board itself, and I selected the Reference Minimal image from there (not a custom Yocto build).
Board 1 (the one with working U-Boot/kernel output): Please find the full serial log attached below — this is the exact output I get every time I power it on. It boots through U-Boot and the kernel normally, but systemd fails to find any unit files under /lib/systemd/system and freezes at “Failed to isolate default target.”
Additional finding: files are present and readable via U-Boot’s raw ls (see attached output — basic.target, sockets.target, etc. all exist under /lib/systemd/system), yet systemd consistently fails with ENOENT on the same files during 10/10 boot attempts — always at the same point.
After leaving the board powered on longer, the kernel additionally logged:
[  305.113299] EXT4-fs (mmcblk2p2): error count since last fsck: 2
[  305.131063] EXT4-fs (mmcblk2p2): initial error at time 1752069120: ext4_mb_generate_buddy:744
[  305.151528] EXT4-fs (mmcblk2p2): last error at time 1752069120: ext4_mb_generate_buddy:744
This points to ext4 block-bitmap/metadata corruption on the eMMC (mmcblk2p2), with the initial error timestamp (Unix time 1752069120, ~July 2025) predating this troubleshooting session — meaning the corruption likely occurred at/near initial flashing rather than in the field. Given this, is a reflash with the updated Easy Installer + reference image expected to resolve this, or does this pattern suggest something else (e.g. an eMMC hardware issue) worth investigating before we reflash?
Board 2 (no output at all): This board gives absolutely no output on the RS232/UART1 interface, not even the U-Boot banner. I did not do anything different when flashing this one — same cable, same port, same recovery procedure, same Easy Installer steps as Board 1. The only difference I’ve observed is the complete absence of any serial output, whereas Board 1 at least reaches the kernel and systemd stage. I have double-checked the RS232 connection and baud rate (115200) settings, and confirmed the cable/adapter works correctly with Board 1.
out.txt (23.3 KB)
Following up:
Since the module could not enter USB recovery mode, i used the SD card boot method (loading Tezi from external media, per the Distro Boot order SD > eMMC > USB) as suggested. This worked and Tezi booted successfully.
However, once in Tezi, the module could not reach the network to download the image feed list (“downloading image list…” never completed, no DHCP lease obtained). To work around this, i loaded the Reference Minimal Image from a separate FAT32 USB stick as a local/offline source, erased the internal eMMC, and installed the image directly from there. This part completed successfully and the module now boots into a clean, working OS.
After this clean reflash, i followed up on the Ethernet issue i ran into during the Tezi/network step, since it persisted even after the reinstall:
i confirmed the Ethernet RX fault is on the module itself, not the carrier board. i swapped the Apalis iMX6 module (Serial# 10932395) to a second, known-good Ixora carrier board and ran the same test — result was identical: PHY link comes up (KSZ9131 attached correctly per dmesg), TX packets increment normally (confirmed working), but RX packets remain at exactly 0 regardless of traffic sent to the module (DHCP offers, direct ping from a PC with static IP, multiple cables/routers tested). Since this reproduces across two separate carrier boards, i believe the fault is in the module’s Ethernet PHY or its connection to the SoC.
I now have a working card, but its ethernet isn’t working.
Apologies for the delayed response, and thank you for the detailed follow-up. I’m glad you were able to recover the module and successfully reinstall the OS using the offline image.
Regarding the Ethernet issue, I was not able to reproduce the behavior on my side. I tested with an Apalis iMX6Q 1 GB V1.1D on an Ixora V1.1B and flashed Torizon OS 7.7.0 using Toradex Easy Installer. After flashing, Ethernet worked as expected, and the module successfully obtained an IP address via DHCP and accessed the network:
torizon@apalis-imx6-10928077:~$ ping -c 3 toradex.comPING toradex.com (52.85.61.72): 56 data bytes64 bytes from 52.85.61.72: seq=0 ttl=247 time=112.896 ms64 bytes from 52.85.61.72: seq=1 ttl=247 time=112.987 ms64 bytes from 52.85.61.72: seq=2 ttl=247 time=112.956 ms--- toradex.com ping statistics ---3 packets transmitted, 3 packets received, 0% packet lossround-trip min/avg/max = 112.896/112.946/112.987 ms
The Ethernet interface also received an IPv4 address normally:
2: ethernet0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 ... link/ether 00:14:2d:a6:bf:cd brd ff:ff:ff:ff:ff:ff altname end0 inet 10.22.1.80/24 brd 10.22.1.255 scope global dynamic noprefixroute ethernet0
Since the original issue reported in this ticket has been resolved, and the Ethernet RX problem appears to be a separate issue, I recommend creating a new ticket so we can investigate it independently. Please include the output of the sudo tdx-info command and the test results you shared here. We can then continue troubleshooting the Ethernet issue separately and determine the appropriate next steps.
With the original issue resolved, I will close this ticket as “Solved,” and we can continue investigating the Ethernet issue in the new ticket.
Please let me know if you have any further questions.
Gabriel Del Monte Schiavi Noda
Toradex
