aktay
September 13, 2017, 4:10am
1
We have a 1920x720 resolution of CD-Tech screen.I am connected with HDMI.We are running our qt application on apalis imx6.The device detects 1024x768 screen resolution. But the resolution of my screen is 1920x720.
How should I make a configuration to get a 1920x720 screen resolution?
Kernel version 2016.11-2.7
root@b2qt-apalis-imx6:~# find /sys/ -name edid
/sys/devices/soc0/soc/20e0000.hdmi_video/edid
root@b2qt-apalis-imx6:~# cat /sys/devices/soc0/soc/20e0000.hdmi_video/edid
0x00 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0x00 0x36 0x74 0x30 0x00 0x01 0x00 0x00 0x00
0x0D 0x17 0x01 0x03 0x80 0x35 0x1D 0x78 0xEF 0x40 0x90 0x9C 0x57 0x52 0x92 0x26
0x1C 0x50 0x54 0x20 0x08 0x00 0x01 0x00 0x01 0x00 0x01 0x00 0x01 0x00 0x01 0x00
0x01 0x01 0x01 0x01 0x01 0x01 0x72 0x27 0x80 0x18 0x71 0xD0 0x2D 0x20 0x58 0x2C
0x45 0x00 0xF8 0xC2 0x21 0x00 0x00 0x1E 0x00 0x00 0x00 0xFC 0x00 0x31 0x39 0x32
0x30 0x58 0x37 0x32 0x30 0x48 0x44 0x4D 0x49 0x20 0x00 0x00 0x00 0x10 0x00 0x00
0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x10
0x00 0x38 0x2D 0x40 0x58 0x2C 0x45 0x00 0x44 0x0A 0x20 0x00 0x00 0x3E 0x01 0x53
0x02 0x03 0x20 0xF1 0x4D 0x05 0x04 0x03 0x13 0x12 0x22 0x21 0x20 0x1F 0x1E 0x1D
0x0F 0x0E 0x23 0x09 0x07 0x07 0x83 0x01 0x00 0x00 0x65 0x03 0x0C 0x00 0x5E 0x1C
0x01 0x1D 0x80 0x18 0x71 0x1C 0x16 0x20 0x58 0x2C 0x25 0x00 0xBA 0x88 0x21 0x00
0x00 0x9E 0x01 0x1D 0x00 0x72 0x51 0xD0 0x1E 0x20 0x6E 0x28 0x55 0x00 0xBA 0x88
0x21 0x00 0x00 0x1E 0x8C 0x0A 0xD0 0x8A 0x20 0xE0 0x2D 0x10 0x10 0x3E 0x96 0x00
0xBA 0x88 0x21 0x00 0x00 0x18 0x01 0x1D 0x80 0xD0 0x72 0x1C 0x16 0x20 0x10 0x2C
0x25 0x80 0xBA 0x88 0x21 0x00 0x00 0x9E 0x01 0x1D 0x00 0xBC 0x52 0xD0 0x1E 0x20
0xB8 0x28 0x55 0x40 0xBA 0x88 0x21 0x00 0x00 0x1E 0x02 0x3A 0x80 0x18 0x71 0x53
0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Could you help me?
Thanx.
max.tx
September 11, 2017, 7:54am
2
Hi
Could you help me?
No.
What is a CD-Tech screen? Weblink?
What exact kernel version are you using.
What from the page you reference do you exactly implement?
If I’m to guess the screen is connected over HDMI then what edid does it announce?
root@apalis-imx6:~# find /sys/ -name edid
root@apalis-imx6:~# cat /sys/devices/soc0/soc/20e0000.hdmi_video/edid
Max
aktay
3
Sorry for missing information.
CD-Tech 1920x720 LCD Module Link
I followed the reference page but could not get results.For this reason I gave a link.
I am connected with HDMI…The device detects 1024x768 screen resolution. But my display screen resolution is 1920x720.How to make a configuration to get 1920x720 screen resolution?
max.tx
September 13, 2017, 3:49pm
4
Hi
Does changing the kernel cmdline in U-Boot help?
e.g. changing vidargs as follows:
Apalis iMX6 # setenv vidargs video=mxcfb0:dev=hdmi,1920x720M@60,if=RGB24 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=32M
Apalis iMX6 # saveenv
If not what is the output of the following in Linux
uname -r
cat /proc/cmdline
dmesg | grep fb
xrandr
Max
I am about to try the exact same thing is a couple of weeks, can I assume this answer was correct?
Hi @dgribben : Actually @aktay did not answer. So we are not sure if the answer was correct. We would be happy if you can try this out. Thanks.
aktay
October 3, 2018, 9:14am
7
Dear @jaski.tx and @dgribben
This solution worked for me.
Perfect. Thanks for the feedback.
I will try that as soon as my sample arrives! Thanks to @aktay !
