Apalis Evaluation Board (Hardware)
I’m currently designing a custom card based on Apalis iMX6.
I would like to ask, if any signal (apalis) change low or high,
when the apalis is on board or the apalis does not exist on the board.
hi @dim_SPA,
May I ask the purpose/use of such that signal?
Satyan Raj
To check the global reset .
Hi @dim_SPA,
You can refer to Apalis Design Guide, Section 3, Power management.
Let me know if you are looking for some other details.
Satyan Raj
