I want to make both CAN interfaces communicate. I’m using the Apalis Evaluation Board with an iMX6Q 1GB module and a DB9 wire I personally soldered (and I verified multiple times that IC11 and IC14 RX/TX are connected).
At the system boot, I load the flexcan
module. Once loaded, I can see the two CAN interfaces with ip a
$ modprobe flexcan
$ ip a
3: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN group default qlen 10
link/can
4: can1: <NOARP,ECHO> mtu 16 qdisc noop state DOWN group default qlen 10
link/can
Then, I set up both interfaces bitrate:
$ ip link set can0 type can bitrate 500000
$ ip link set can1 type can bitrate 500000
$ ip link set can0 up
$ ip link set can1 up
So far, so good. Now, I open two additional terminal windows and execute candump can0
(resp. can1
) on each. On the initial terminal window, I execute cansend can0 123#11223344
. Nothing appears in any of the windows… The CAN1 RX and TX leds are lit up, while only the CAN2 RX is lit up.
Furthermore, I added the option loopback on
when initializing the CAN interfaces and this time, candump
outputs something.
Any idea why this is not working? Thanks in advance.
