I need to interface 2 analog cameras for my application and I came across this Analogue Camera Adapter in your online shop. But in the specifications, it was mentioned that it is not supported in Embedded Linux BSP 5. Currently I have 2 boards running TorizonCore 5.7 and TorizonCore 6. Is there any possibility of Analogue Camera Adapter supporting for current BSP or do you have any recommended 3rd party adapter I can use for testing ?
Thank you.
Hardware
Apalis iMX8QM 4GB WB IT v1.1 B
Ixora V1.1A
with TorizonCore 5.7
Hi @imeshsps ,
As rightly mentioned by you ACA is no longer supported in BSP 5 also Apalis iMX8 do not feature parallel interface. That said you can buy or implement design to interface analog camera over different bus like MIPI CSI, mPCIe etc.
e.g 8-channel frame grabber and 8-channel audio capture | Model 1012
ADV7282A-M ADV7282A Datasheet and Product Info | Analog Devices
Note: This is not recommendation neither we have validated above card. Need to be tested at your end.
Ritesh Kumar
Hey @ritesh.tx ,
Thank you very much for your suggestions. I’ll check those options.
