Analog video inputs VF61 (WEC7)
Hi everyone!
Is there any solution yet for Video Capturing for VF61 modules?
Some information, libs or suggestions?
Regards.
Martín.
I’m afraid the analog video input is not supported in our WEC7 BSP.
The performance of the VF61 would limit the usage to very simple applications. It would also be an interface which is not compatible to any other Colibri module. Finally there’s no support from Freescale, so we would need to write the driver from scratch.
As an alternative you could look into USB cameras, which already compress the video stream.
ok, thanks!
