Based on the information in the Aquila AM69 documentation, this behavior is expected and related to the USB_2_EN signal changes between V1.0A and V1.1A.
Background on USB_2_EN Signal Changes
The USB_2_EN signal behavior changed between the Aquila AM69 V1.0A and V1.1A revisions. According to the errata documentation, the V1.0A had Errata #2 (HAR-11135) where the “USB_2_EN signal needs to be inverted (by default it’s active low output from the bridge)” (1).
The errata states that customers could not use the USB_2 interface with BSP 6-based software, but “the interface functions properly with operating systems based on BSP 7” (1). A software fix addressing this issue was implemented in BSP 7 (1).
V1.1A Changes
The V1.1A revision fixed this errata (1). However, this means the signal behavior has changed from what you experienced with V1.0A + development board combination.
Impact on Your Custom Carrier Board
Since your custom carrier board hardware is expecting an active high signal (based on your V1.0A + development board experience), but the V1.1A module now has the corrected signal behavior, you may need to:
- Verify your carrier board design - Check if your regulator enable circuit can work with the corrected USB_2_EN signal polarity from the V1.1A module
- Review the signal requirements - The V1.1A should provide the proper signal according to the Aquila family specification
Recommendation
Since you’re using BSP 7 with the V1.1A module, the USB_2_EN signal should be functioning according to the intended specification. If your custom carrier board was designed based on the V1.0A behavior (which had the errata), you may need to review your carrier board’s USB_2_EN handling circuit to ensure compatibility with the corrected V1.1A signal.
You can also use the tdx-info command to get detailed information about your current module and software versions. More information about this tool is available at: Getting Device Information with Tdx-Info | Toradex Developer Center
