Altering the DTS(i) file
I’m trying to do someting ‘simple’ but somehow can’t find the correct information for it anywhere…
For example this part of the colibri dts.
pinctrl_gpio2: gpio2-grp { /* Camera */
		fsl,pins = <
			MX6UL_PAD_CSI_DATA04__GPIO4_IO25	0x74 /* SODIMM 69 */
			MX6UL_PAD_CSI_MCLK__GPIO4_IO17		0x14 /* SODIMM 75 */
			MX6UL_PAD_CSI_DATA06__GPIO4_IO27	0x14 /* SODIMM 85 */
			MX6UL_PAD_CSI_PIXCLK__GPIO4_IO18	0x14 /* SODIMM 96 */
			MX6UL_PAD_CSI_DATA05__GPIO4_IO26	0x14 /* SODIMM 98 */
Where can i find what those 0x74 and 0x14 mean?
Can’t locate it in the imx6ul reference manual, nor does searching internet help.
Hello @Michielt ,
Based on the DTS that you pasted, I would assume that you are using a Colibri i.MX6ULL, can you confirm that point?
If that is the case, this article explains the meaning of these hexadecimal values for i.MX6ULL , and other SOC’s:
Josep
Hello @josep.tx,
It’s indeed the imx6ull, but the information provided is the part i already found.
If you look at the posted dts node, this doesn’t correspond…
0x14 ‘0001 0100’ and 0x74 ‘0111 0100’ aren’t possible with that given info because bit 1 and 2 are reserved.
So for some reason the GPIO’s above gpio1.9 don’t use the 16bit format and i’m looking for that alternative format.
Hello @Michielt ,
That seems to be an documentation error on our side, related to this topic:
Can you tell us which BSP version are you using?
Josep
Hm, indeed, the file i was looking at was old…
More recent file:
	pinctrl_gpio2: gpio2grp { /* Camera */
		fsl,pins = <
			MX6UL_PAD_CSI_DATA04__GPIO4_IO25	0x10b0 /* SODIMM 69 */
			MX6UL_PAD_CSI_MCLK__GPIO4_IO17		0x10b0 /* SODIMM 75 */
			MX6UL_PAD_CSI_DATA06__GPIO4_IO27	0x10b0 /* SODIMM 85 */
			MX6UL_PAD_CSI_PIXCLK__GPIO4_IO18	0x10b0 /* SODIMM 96 */
			MX6UL_PAD_CSI_DATA05__GPIO4_IO26	0x10b0 /* SODIMM 98 */
I’m not using a BSP, just starting from scratch to learn the whole process from bootloader onwards.
So my assumption that this didn’t change was wrong. (as in: thought age didn’t make a difference)
