Adv7280-m problem with Apalis iMX8
Hi @ramin_rad
I have with me the ADV7280AMEBZ Evaluation board. We have a custom adapter for it to CSI in order to connect it to the Ixora Board.
Our iMX6 modules have a device tree with a node for the ADV7280 already there so I’m going to test with either the Apalis iMX6 (device-trees/dts-arm32/imx6q-apalis-ixora-v1.2.dts at toradex_5.4-2.3.x-imx · toradex/device-trees · GitHub) or with the Colibri iMX6 (device-trees/dts-arm32/imx6dl-colibri-cam-eval-v3.dts at toradex_5.4-2.3.x-imx · toradex/device-trees · GitHub) to check what progress can I do.
Hi @gclaudino.tx ,
How are you doing?
does iMX6 device tree and driver supports mipi csi? because I’m using adv7280-m and need CSI
I found this line in driver source file which shows there is no MIPI support:
/* ADV7280 is always parallel IF */
adv7280_data.sen.mipi_camera = 0;
I’m asking because I have an apalis iMX6Q and I can test my module with it to ensure hardware and camera correctness
Hi @gclaudino.tx and @ramin_rad
Did you have any luck? We are also getting “mxc-mipi-csi2.0: is_entity_link_setup, No remote pad found!” with ADV7280A-M and imx8qxp.
Thank you
– Peter
Hi @petero ,
@gclaudino.tx is not working for Toradex anymore.
We’ll pick this topic up and come back to you.
Kevin
Hi @kevin.tx
Thank you very much. Not to worry, we found a solution via the nxp forum. Thank you, Peter
Hi @petero,
Thanks for letting us know.
If you like you can share the nxp forum link here, for others facing the same question.
Kevin
Thank you @kevin.tx, good idea.
This is how we solved it:
And a couple more references:
Thank you
– Peter
