we have a 7inch TFT Liquid Crystal Display module with LVDS interface (G070Y2-L01 / Data Module AG) and use the Apalis_iMX6_LinuxImage-qtV2.6_20160615 Image build with “bitbake -k angstrom-qt-x11-image”.
In U-Boot we use imx6q-apalis-ixora.dtb device tree and change the vidargs Var :
vidargs=mxc_hdmi.only_cea=1 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off fbmem=32M
to
vidargs=video=mxcfb0:dev=ldb
After that we boot. Unfortunately the display has an offset (shift to left and bottom ).
From the datasheet it looks like your display does not like Hsync, Vsync signals at all. For this we do not have a real solution. This discussion might be helpfull which allows you to set the Hsync to 0.
Hi Max,
thanks for your response. The problem is now fixed. I add a new “display-timings” entry to my device tree and adjust the timings/resolution. For the G070Y2-L01 i take this setup:
" From the datasheet it looks like your display does not like Hsync, Vsync signals at all. For this we do not have a real solution. This discussion might be helpful which allows you to set the Hsync to 0. "
I try : hsync-acttve = <0>; vsync-active = <0>; & hsync-active = <1>; vsync-active = <1>; . Both worked.
One additional Question:
How can i select/switch to other display-timings from the dtb ?( e.g. timing_xga, timing_wxga )
When i run fbset -i on target i only see the mode correspond to my added display-timing. Can i select them from BL via vidargs Var ?
