Hi @bw908 ,
Namely, I unpacked the output tar.zst in my output directory, and if I browse down to ostree/deploy/torizon/deploy/[commit hash]/etc/ and open the group
file, I can see the groups are present.
Great, it is a good way to verify your custom image. With this I don’t think the issue is related to your image.
So it is getting applied to the actual image - which confirms the build environment is set up correctly and the change should be present. yet I’ve done numerous images unpack output
and deploy
calls and they have not materialized - the files stubbornly stay empty of my new entries.
I was able to reproduce your issue when deploying the image through SSH via torizoncore-builder deploy
and at least in this situation I have a possible explanation for it.
The reason is due to how OSTree, the program responsible for versioning/deploying the images, works: If a tracked file in /etc
is modified in relation to its counterpart in /usr/etc
, OSTree will not change it, even if the update has a newer version of it, as said here: Atomic Upgrades | ostreedev/ostree
/usr/etc
is the “default configuration” of the image, and OSTree uses it as a point of reference to track any changes made in /etc
In particular /etc/group
and /etc/gshadow
are modified when first logging in on a new TorizonCore install, so unless you undo the modifications these two files won’t be affected by any updates made using torizoncore-builder deploy
This shouldn’t happen when installing the image through TEZI though, as OSTree versioning is reset.
I suggest you try the following:
Install a vanilla TorizonCore image via TEZI on your module, version should be the same you used for the custom image;
Login as user torizon, then check the differences between /etc
and /usr/etc
with:
sudo ostree admin config-diff
group
and gshadow
should be marked with ‘M’, meaning they are modified in relation to /usr/etc
sudo rsync -avh /usr/etc/ /etc/ --delete
This command will also reset the torizon user password to torizon
Check again with sudo ostree admin config-diff
. There should be no output, or at the very least group
and gshadow
should not be present.
On your host machine deploy your custom image that has the modified /etc/group
and /etc/gshadow
torizoncore-builder images unpack <your custom image directory>
torizoncore-builder union <branch name, can be anything>
torizoncore-builder deploy <branch name> --remote-host <SoM IP> --reboot
After the module finishes rebooting, login again (remember that the password has been reset to torizon
All changes should be present on the image.
See if this helps you.
Lucas Akira
