Add libftd3xx.so to Linux BSP 6.4
What is the best method to add binary file e.g. libftd3xx.so(FTDI) to bitbake Linux image ?
Hello @MariusM
Thanks for reaching out to the Toradex Community!
You will have to write a recipe to add the shared object.
This post on stackoverflow discusses a similar topic: Yocto add Shared Library - Stack Overflow
Could you please take a look and let us know how that goes?
@rudhi.tx Thank you for your answer, thanks to it I found the documentation.
yoctoproject [15 ]Working with Pre-Built Libraries
and example (copy from doc)
SUMMARY = "libfoo sample recipe"
SECTION = "libs"
LICENSE = "CLOSED"
SRC_URI = "file://libfoo.so"
COMPATIBLE_HOST = "x86_64.*-linux"
INSANE_SKIP:${PN} = "ldflags"
INHIBIT_PACKAGE_STRIP = "1"
INHIBIT_SYSROOT_STRIP = "1"
SOLIBS = ".so"
FILES_SOLIBSDEV = ""
do_install () {
        install -d ${D}${libdir}
        install -m 0755 ${WORKDIR}/libfoo.so ${D}${libdir}
