Adding Kernel Command Line Arguments to Torizon Yocto Build
To add the kernel command line argument clk-imx8mp.mcore_booted=1 to your Torizon minimal build, you have several approaches depending on your workflow.
Approach 1: Using TorizonCore Builder (Recommended)
If you’re building with Yocto but want to customize kernel arguments afterwards, you can use TorizonCore Builder (1). This approach works with an existing Torizon OS image:
Using Configuration YAML File
Create a tcbuild.yaml file with your kernel arguments (1):
customization:
kernel:
arguments:
- clk-imx8mp.mcore_booted=1
(1)
Then build your custom image (1):
$ torizoncore-builder build --file tcbuild.yaml torizon-core-docker-<your-module>-Tezi_<version>.tar
(1)
Using Standalone Commands
Alternatively, you can use standalone TorizonCore Builder commands (1):
- Unpack your base image (1):
$ torizoncore-builder images unpack torizon-core-docker-<your-module>-Tezi_<version>.tar
(1)
- Set the custom kernel argument (1):
$ torizoncore-builder kernel set_custom_args clk-imx8mp.mcore_booted=1
(1)
- Merge changes (1):
$ torizoncore-builder union custom-branch
(1)
- Deploy the custom image (1):
$ torizoncore-builder deploy custom-branch --output-directory torizon-core-docker-<your-module>-Tezi_<version>.CUSTOM
(1)
Approach 2: Direct Yocto Integration
For integrating kernel arguments directly into your Yocto build, you’ll need to modify your Yocto configuration. Based on the community discussions (2), you can create a bbappend file for your kernel recipe.
Create a configuration fragment file (e.g., custom-cmdline.cfg) with your kernel argument (2):
# Custom kernel command line arguments
CONFIG_CMDLINE="clk-imx8mp.mcore_booted=1"
CONFIG_CMDLINE_EXTEND=y
Then add this configuration fragment to your kernel recipe’s SRC_URI (2).
Verification
After deploying your custom image, you can verify the kernel arguments are applied (1):
# cat /proc/cmdline
(1)
This should show your custom kernel argument clk-imx8mp.mcore_booted=1 in the command line.
Important Notes
- The RemoteProc framework requires specific device tree overlays to be enabled (3)
- Make sure you’re using the correct overlay for your hardware platform (3)
- When building custom Yocto images, ensure version compatibility between different components (4)
The TorizonCore Builder approach is generally recommended as it provides a more streamlined workflow for kernel customizations while maintaining the benefits of the Torizon platform.
