lucam
November 2, 2017, 4:40pm
1
I need to add Google fonts directly in the yocto build. Those fonts must be recognized by Qt because I have to use them in the software GUI.
Those are the fonts:
Montserrat
Open Sans
Yantramanav
How can I do? I could not find resources on this topic.
Thanks for any help you can give.
max.tx
November 2, 2017, 5:37pm
2
Hi
You would write a recipe which does whatever needed to get packages with your fonts and then add those packages to your image.
e.g. have a look at this recipe which does package the liberartion ttf fonts.
Max
lucam
November 3, 2017, 4:49pm
3
Ok thanks. In the next days I’ll take a look to this recipe.
When I get some news I will write again.
lucam
January 17, 2018, 1:57pm
4
It’s been a while, but I update you.
Starting from that recipe I managed to install custom fonts and licensing.
I used also this recipe to help me to install also the license into the system.
Thanks a lot.
max.tx
January 17, 2018, 10:54pm
5
Great that this works. Thanks for the feedback.
