I’m setting up a tcbuild.yaml file for my image build. We are using an internal docker registry that cannot be easily secured (except with self-signed certs). I therefore need to use the insecure-registry parameter to be able to fetch bundles.
Is there a way to specify --dind-param parameter when using tcbuild.yaml file and the torizoncore-builder build command?
Hi @hordur !
For now, there is no way to pass dind-param
, unfortunately.
As a workaround, you could use the second form of the bundle section:
- fetch the image using the TorizonCore Builder’s bundle command,
- modify your
tcbuild.yaml
to reference the corresponding bundle directory- e.g.: use
output/easy-installer/bundle/dir
instead ofoutput/easy-installer/bundle/compose-file
- e.g.: use
- build it
Let me know if this helps you.
Hi, Thanks for the workaround, I’ll try that.
It would be great to get the other parameter supported in the yaml file, or as a command line option to the build command (since it is more of a system option than a setting of the image being built). Should I create a feature request to suggest this, or is this question sufficient?
Thanks,
Hi @hordur !
For a feature request, would be better to create a question there. You can reference this question there.
Hi @henrique.tx !
Is there a way to pass the certificates to dind container?
‘/etc/docker/certs.d/‘server host’/domain.crt’
‘/etc/docker/certs.d/‘server host’/domain.key’
‘server host’ eg: registry.myserver.com
Dear @pkg_su ,
Thanks for joining the community. Please feel free to explore and ask any questions that you may have.
Can you please start a new topic about this question?
Guilherme
