Accessing extenal memory
I defined the colibri_pin 150 as EIM_LBA_B (altf4) . The address valid is active low. How can I configurate this signal to active high?
Please refer to the i.MX7 Reference Manuals to learn about the options to configure the EIM properties.
You can use our MapMem library to access the CPU registers directly.
