Hi all,
We are using Vf61 with linux 2.7 for an application. As part of application we are connecting the Toradex module and and Winodws based PC to same local network (Assume toradex IP is 192.168.10.1 and and Windows IP is 192.168.10.3). There is a File Data.bin in *D:* Folder of Windows. The application in Toradex is devloped with qt. Can you suggest method to read contents of File Data.bin from user space program of Toradex?
Regards
