Module: Aquila AM69 on Aquila Dev Board OS: Torizon OS 7.6.0+build.36 (scarthgap)
Goal: build and load a bare-metal “hello world” R5F firmware on MAIN_R5F1_0 via Linux remoteproc, with UART output visible on the dev board’s UART4 debug port.
Observations:
Torizon IDE Extension (3.4.2) has no R5F project template for Aquila AM69.
/lib/firmware/contains onlyapp_remoteswitchcfg_serverfor R5F0_0 (CPSW9G helper); no example firmware for R5F1, R5F2. -
/lib/firmware/is on read-only OSTree mount;firmware_class.path → /var/firmwareworks as a runtime workaround but doesn’t survive reboot. -
The K3 R5F driver rejects firmware ELFs whose only PT_LOAD segments target DDR (
bad phdr da 0xa1100000); a working reference firmware (the CPSW one) has segments at ATCM (0x0), BTCM (0x41010000), and DDR — implying the bare-metal pattern requires reset vectors in TCM, not DDR.
Request: prebuilt example firmware (.xer5f) for one of the available MAIN R5F cores, OR documented build procedure for producing one from the PDK against Aquila’s device tree.
