About loading tflite model converted with tensorflow ops enabled in imx8mp
@alvaro.tx
Hi, thank you for repley.
OK. I see.
Do you know when version 5.4-2.3 will be released?
Is BSP version 5.4-2.3 the next release?
Can I have how to get the information that the BSP version support TFlite 2.4.0 or not support, when the BSP version is released.
Hi @akito, I’ve just opened an internal ticket to trigger an internal discussion. We will update you if there is more info.
However, I was just checking that we updated to 5.4.70-2.3.3 in our latest BSP 5.4.0 release just this week:
https://www.toradex.com/ja-jp/news/bsp-layers-reference-images-yocto-project-5-4-0-quarterly
Can you try with this image/SDK and see if you have the newer TFLite 2.4.0?
Hi, @alvaro.tx
I tried to build, but i have error.
I changed only version from following manual
Building Machine Learning Software with Reference Images for Yocto Project (toradex.com)
repo init
$ repo init -u https://git.toradex.com/toradex-manifest.git -b refs/tags/5.4.0 -m tdxref/default.xml
5.2.0 —> 5.4.0
git clone
$ git clone -b zeus-5.4.70-2.3.3 git://source.codeaurora.org/external/imx/meta-imx ~/yocto-ml-build/meta-imx
2.3.1 —> 2.3.3
error message
arm-compute-library-20.08.imx+gitAUTOINC+203f466760-r0 do_compile: scons build execution failed.
Where is the problem?
Hi @akito, thank you for your comments. We will check this.
@denis.tx Can you check, pls? Our latest documentation mentioned 5.2.0 but we just released 5.4.0 that it should include the needed TFLite 2.3.3 version but there is a compilation error :pray:
Thanks a lot,
Alvaro.
Hi @alvaro.tx , I will open a ticket to our team to update the article for building TFLITE 2.4.0.
Yes, the developers of course did not complete the project!
Dear @akito , just a quick mention that we updated our TensorFlow Lite / eIQ info for BSP 5.7.0. Feel free to try this out again.
Kind regards,
Alvaro.
