we have a AD7879 touchscreen attached to a Colibri iMX6ULL board. Driver atmel_mxt_ts is loaded and xinput says the device is enabled.
Does anybody has an idea what could be the problem?
Thanks in advance
Thanks in advance
Hi gringo
Which type of touchscreen are u using? Resistive or Capacitive? Which carrierBoard are u using? The driver atmel_mxt_ts is a capacitive touchscreen driver?
As i can see AD7879 is a resistive touch screen driver. see link
How did you exactly connected the touchscreen?
Hi Jaski.tx,
it’s a capacitive touchscreen and with use it on an Aster carrier board.
Afaik atmel_mxt_ts is a capacitive touchscreen driver.
The driver which is actually loaded is an atmel_mxt_ts, which is a capacitive touch driver. I do not have a clue, why the device is identified as AD7879.
The touchscreen is connected via an i2c bus.
The AD7879 is a restive touch controller on the Colibri iMX6ULL module.
The capacitive touch controller is not enabled by default in our device tree. You need to enable the atmel_mxt_ts driver you need to adjust the device tree according to this instructions:
I set
fdt_fixup ‘fdt addr ${fdt_addr_r} && fdt set /soc/aips-bus@02100000/i2c@021a0000/atmel_mxt_ts@4a status okay’
in the bootloader parameters, but it doesn’t seem to work.
Can you send a dmesg log? Thanks.
