Can you recommend a 7" HDMI + USB capacitive touch screen display for imx7d.
The Colibri iMX7 module does not natively support an HDMI. The only video interface supported by Colibri iMX7 is a Parallel RGB LCD interface. Some of our carrier board has (Aster/Iris/Colibri evaluation board) have an additional IC to convert Parallel RGB LCD to VGA or/and LVDS). Same way you can design a custom carrier board with Parallel RGB LCD to HDMI converter. Or you can use a Colibri iMX6 module which has a native HDMI support. Then you can use pretty much any HDMI + USB capacitive touch screen display.
