7" Capacitive Display not working
I tried connecting the 7" Display to my development board but it’s not working. It keeps flashing the screen with multiple coloured lines on a white background.
I am currently developing for a IMX6DL v1.1A, Aster carrier board v1.1B, on a Ubuntu 20.04 PC.
Here’s the setup:
The connectors seem to be correct, from what I’ve gathered.
Looking at a serial monitor, the board doesn’t even finish booting. Instead, it seems to continually try to reboot the display:
It keeps writing that to the serial monitor.
How should I proceed?
I’ve already found what the issue was. Apparently the power supply wasn’t able to provide sufficient current. Changed it and now it works.
Perfect that you solved your issue.
