I connected a 9V Supply to the ixora board V1.1A with Apalis imx6 mounted on it. LVDS connector cable is connected with the display and IXora board. when switch on the board, no display is coming.
Please suggest the settings.
Dear @mania,
Could you download the installer from here : https://developer.toradex.com/knowledge-base/first-steps-with-capacitive-touch-display-7-inch-parallel#Connections_on_Iris_Viola_Colibri_Evautation_Board_Apalis_Evaluation_board and install it on Apalis IMX6. The installer also supports for 10-inch display as well.
I didn’t get any display, so how can I install the driver software for touch setup.
Dear @mania,
Could you connect HDMI monitor or use Remote display : https://developer.toradex.com/knowledge-base/remote-display to access WinCE desktop explorer and then install it.
Let us know if you face any issues with this.
I’m having the same issue as well, I tried installing WinCE from the Toradex Easy Installer, but it never boots up on an HDMI monitor after installation so I can’t get to the WinCE desktop explorer. What are my other options to setup this display with the same specifications?
Could you please create a new topic and fully specify versions of HW and SW you are using?
