Hello everyone,
I get an error when compiling the B2qt image.
ERROR: Task (/home/pc_742/Toradex/Yocto_Images/bt2qt_son/meta-boot2qt/sources/meta-qt5/recipes-qt/qt5/qtwebengine_git.bb:do_compile) failed with exit code '1'
When I follow this document ( How to set up Qt Creator to cross compile for embedded Linux | Toradex Developer Center ) after compile process started, I’ve belowed error. In attached you can find the detailed log files.Error Log File
| ninja: build stopped: subcommand failed.
| Makefile.gn_run:365: recipe for target 'run_ninja' failed
| make[3]: *** [run_ninja] Error 1
| make[3]: Leaving directory '/home/pc_742/Toradex/Yocto_Images/bt2qt_son/meta-boot2qt/build-apalis-imx8/tmp/work/aarch64-mx8-poky-linux/qtwebengine/5.15.0+gitAUTOINC+387fb9377d_623647821a-r0/build/src/core'
| Makefile:82: recipe for target 'sub-gn_run-pro-make_first' failed
| make[2]: *** [sub-gn_run-pro-make_first] Error 2
| make[2]: Leaving directory '/home/pc_742/Toradex/Yocto_Images/bt2qt_son/meta-boot2qt/build-apalis-imx8/tmp/work/aarch64-mx8-poky-linux/qtwebengine/5.15.0+gitAUTOINC+387fb9377d_623647821a-r0/build/src/core'
| Makefile:78: recipe for target 'sub-core-make_first' failed
| make[1]: *** [sub-core-make_first] Error 2
| make[1]: Leaving directory '/home/pc_742/Toradex/Yocto_Images/bt2qt_son/meta-boot2qt/build-apalis-imx8/tmp/work/aarch64-mx8-poky-linux/qtwebengine/5.15.0+gitAUTOINC+387fb9377d_623647821a-r0/build/src'
| Makefile:48: recipe for target 'sub-src-make_first' failed
| make: *** [sub-src-make_first] Error 2
Do you have any suggestion ?
Best regards
