I have problems when using both of the low power modes for iMX6ULL with Linux Console Image 2.8b3.111
Using either of the commands:
$ echo mem > /sys/power/state
$ echo standby > /sys/power/state
I get the following message
[ 47.651320] PM: Syncing filesystems ... done.
[ 47.716495] Freezing user space processes ... (elapsed 0.001 seconds) done.
[ 47.725354] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 47.734600] Suspending console(s) (use no_console_suspend to debug)
However, for suspend to memory, the system immeditely goes into a reboot
U-Boot 2016.11-2.8.3+gaca804c (Jun 26 2018 - 16:29:39 +0000)
For standby I get the following error on wakeup:
[ 2857.086021] mwifiex_sdio mmc1:0001:1: EVENT: BT coex wlan param update
[ 2857.087395] mwifiex_sdio mmc1:0001:1: None of the WOWLAN triggers enabled
[ 2857.227623] PM: suspend of devices complete after 143.876 msecs
[ 2857.229208] PM: late suspend of devices complete after 1.560 msecs
[ 2857.230723] PM: noirq suspend of devices complete after 1.491 msecs
[ 2857.230731] Disabling non-boot CPUs ...
[ 2857.231986] PM: noirq resume of devices complete after 1.141 msecs
[ 2857.233364] PM: early resume of devices complete after 1.066 msecs
[ 2857.235480] gpmi-nand 1806000.gpmi-nand: mode:5 ,failed in set feature.
[ 2857.264014] mmc1: error -110 during resume (card was removed?)
[ 2857.270592] Suspended for 21.226 seconds
[ 2859.307526] fec 20b4000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 2860.267082] mwifiex_sdio mmc1:0001:1: Firmware wakeup failed
[ 2860.267262] PM: resume of devices complete after 3033.618 msecs
[ 2860.353651] Restarting tasks ... [ 2860.389159] mwifiex_sdio mmc1:0001:1: PREP_CMD: FW in reset state
[ 2860.395440] mwifiex_sdio mmc1:0001:1: PREP_CMD: FW in reset state
[ 2860.402870] done.
[ 2860.417697] mwifiex_sdio mmc1:0001:1: info: shutdown mwifiex...
[ 2860.457867] mwifiex_sdio mmc1:0001:1: PREP_CMD: card is removed
[ 2860.464016] mwifiex_sdio mmc1:0001:1: PREP_CMD: card is removed
root@colibri-imx6ull:~# [ 2860.552019] mwifiex_sdio mmc1:0001:1: PREP_CMD: card is removed
[ 2860.677259] mwifiex_sdio mmc1:0001:1: PREP_CMD: card is removed
[ 2860.747329] mwifiex_sdio mmc1:0001:1: PREP_CMD: card is removed
[ 2860.852461] mmc1: card 0001 removed
[ 2861.153870] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 2861.179770] mmc1: error -22 whilst initialising SDIO card
[ 2861.300646] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 2861.326131] mmc1: error -22 whilst initialising SDIO card
[ 2861.451666] sdhci-esdhc-imx 2194000.usdhc: no support for card's volts
[ 2861.477047] mmc1: error -22 whilst initialising SDIO card
(this repeats endlessly)
Can anyone suggest what needs to be done to get the lower power modes (particularly suspend to memory) working correctly?
