LVDS Panel with Smarc eval board
Hi, we use the SMARC eval board with a IMX95 SMARC SoC. We connected a Panel Ampire AM1280800 on LVDS connector. Now I would like to develop the device tree overlay file. I saw there is a file “toradex-smarc-imx95_panel-cap-touch-10inch-dsi_overlay.dtbo“. But I can’t find the source file .dts for that. Where can I find it?
Actually I loaded this file and a self written on too, but either does give out a display.
I’d be glad to help! To provide you with the most accurate guidance for your SMARC iMX95 setup with the Ampire AM1280800 LVDS panel, could you let me know which OS and version you are using? You can use the tdx-info command to get detailed information about your system - more details at this link.
Device Tree Source Files Location
For finding the device tree source files (.dts), you can access them through the Toradex Device Tree Overlays repository on Github (1)(2). This repository contains the source files for all the pre-built overlays provided by Toradex.
Available SMARC iMX95 Overlays
According to the documentation, for SMARC iMX95 (starting from version 7.3.0), the available display overlays include (1):
  • DSI to HDMI: toradex-smarc-imx95_dsi-to-hdmi_overlay.dtbo
  • Capacitive Touch Display 10.1" DSI: toradex-smarc-imx95_panel-cap-touch-10inch-dsi_overlay.dtbo
  • Capacitive Touch Display 10.1" LVDS: toradex-smarc-imx95_panel-cap-touch-10inch-lvds_overlay.dtbo
  • LVDS (LG LP156WF1, Dual Ch, 1080p, 18bit): toradex-smarc-imx95_panel-lvds-dual-channel-1080p_overlay.dtbo
  • eDP AUO G156HAN03.0: toradex-smarc-imx95_panel-edp-142mhz_overlay.dtbo
LVDS Panel Considerations
For your Ampire AM1280800 LVDS panel, you’ll likely want to reference the LVDS overlays as a starting point. The toradex-smarc-imx95_panel-cap-touch-10inch-lvds_overlay.dtbo would be the closest match for an LVDS interface (1).
Once you specify your OS version, I can provide more targeted guidance on configuring your custom overlay for the Ampire panel.
What do I have to do? Only load the file toradex-smarc-imx95_panel-cap-touch-10inch-lvds_overlay.dtbo ? Or are there other things to do? Do I have to disable the HMDI port?
I’d be glad to help! To provide you with the most accurate guidance for your SMARC iMX95 setup, could you let me know which OS and version you are using? You can use the tdx-info command to get information about your system - more details at this link.
Loading Device Tree Overlays
For SMARC iMX95, the available LVDS overlay is toradex-smarc-imx95_panel-cap-touch-10inch-lvds_overlay.dtbo (1). However, this overlay is specifically designed for Toradex’s Capacitive Touch Display 10.1" LVDS and may not work directly with your Ampire AM1280800 panel.
Pre-enabled Overlays
According to the documentation, SMARC iMX95 has pre-enabled SPIDEV overlays by default (1):
  • toradex-smarc-imx95_spi0-cs0_spidev_overlay.dtbo
  • toradex-smarc-imx95_spi0-cs1_spidev_overlay.dtbo
  • toradex-smarc-imx95_spi1-cs0_spidev_overlay.dtbo
  • toradex-smarc-imx95_spi1-cs1_spidev_overlay.dtbo
HDMI and Display Configuration
The documentation indicates that for SMARC iMX95, native HDMI is “Not supported” (2)(1). The available display options are:
  • DSI to HDMI adapter
  • DSI interfaces for displays
  • LVDS interfaces
  • eDP interface
Custom Panel Configuration
Since your Ampire AM1280800 panel has different specifications than the standard Toradex displays, you’ll likely need to create a custom overlay with the correct timing parameters for your specific panel.
Once you provide your OS version information, I can give you more specific guidance on how to configure the overlay for your Ampire panel and the proper steps to load it.
SMARC-iMX95_Reference-Multimedia-Image
Hi @inetronic!
I recommend using the toradex-smarc-imx95_panel-cap-touch-10inch-lvds_overlay.dts as a starting point and then making the modifications for your display.
While I personally prefer to disable all unused interfaces and overlays when creating a new device tree overlay, it is not mandatory to disable the HDMI port.
Best regards.
This works, thank you
